Rolling Motion of a Rigid Object
The problem involves a uniform solid disk and a uniform hoop released from rest at the top of an incline of height h, rolling without slipping. The objective is to determine which object reaches the bottom first and to calculate their speeds in terms of h.
  • Participants discuss the application of conservation of energy, considering both translational and rotational motion. There are questions about how to calculate the moment of inertia for each object without specific values. Some participants suggest substituting known values for the moment of inertia for different shapes.
The discussion is ongoing, with participants exploring different interpretations of the problem and clarifying concepts related to moment of inertia. There is no explicit consensus on the final outcome, but guidance has been provided regarding the use of energy conservation and the relationship between linear and angular motion.
Participants note the absence of specific values for mass and radius, which may affect the calculations. There is also some confusion regarding terminology, particularly around the concept of a "2-sphere" and its implications for the problem.
APool555
I have no clue where to start on this problem. I appreciate any help. Thanks.
A uniform solid disk and a uniform hoop are placed side by side at the top of an incline of height h. If they are released from rest and roll without slipping, which object reaches the bottom first? Verify you answer by calculating their speeds when they reach the bottom in terms of h.
We assume no friction ? No ? Ok then use conservation of energy :
[tex]MgLsin( \theta) = \frac{1}{2}I \omega^2 + \frac{1}{2}Mv^2[/tex]
v is the speed, omega the angular speed and L is the length of the incline which makes an angle theta with the horizontal.
The clue really is to see the motion of a rigid object as the sum of a translation and a rotation : hence the two terms on the RHS, which express the kinetic energy
Keep in mind that [tex]v = \omega R[/tex] where R is the radius of the object
Just fill in the I (rotational inertia about the center of mass of the rotating object) for both objects and solve for v so you can compare
oh i just realized, the Lsin(theta) is equal to the height h...so you can replace them...
marlon
Ok, I can see that now. h=Lsin(theta)
How do I fill in the I for both objects when I'm given no values at all?
They should have been given. You can calculate them yourselves by using 3-D-integration, but let's keep it simple
For the hoop I = MR²
For the disk I = (1/2)MR²
For a sphere I =(2/5)MR²
So assume all objects have same radius R and same mass M, which one will come down first and which one last ?
Be sure you write v as a function of h, I and R and then substitute the I-values for each object...
marlon
Marlon said:
(...) For a sphere I =(2/5)MR²(...)
*For a 2-sphere of mass M & radius R,the moment of inertia wrt a rotation axis (chosen as Oz) passing through the center of the 2-sphere is
[tex]I_{Oz}^{2-sphere} = \frac{2MR^{2}}{3}[/tex]
*For a ball in [itex]\mathbb{R}^{3}[/itex] of mass M and radius R,the moment of inertia wrt a rotation axis (chosen as Oz) passing through the center of the ball is
[tex]I_{Oz}^{ball \subset \mathbb{R}^{3}} =\frac{2MR^{2}}{5}[/tex]
Daniel.
:smile: :smile: :smile: :smile:
What the hell is a two dimensonal sphere ?
You are talking about a spherical shell...that is not the same...aahhhhh
TO the OP : let's also study the spherical shell... :smile:
marlon
A 2-sphere...yes yes yes :) :) :)
marlon
2-Sphere is the surface of (implicit) equation (in cartesian coordinates)
[tex]x^{2}+y^{2}+z^{2}=R^{2}[/tex]
and it's not funny not to know what a 2-sphere is...:rolleyes:
Daniel.
  • · Replies 35 ·
  • · Replies 21 ·
  • · Replies 60 ·
  • · Replies 32 ·
