Transducer terminology question
The output signal of a rotary potentiometer transducer measuring angular displacement is voltage, as confirmed by the discussion participants. The potentiometer acts as a variable resistor, changing its resistance in response to angular displacement, which in turn affects the output voltage measured by a Digital Multimeter (DMM). The key outputs of a transducer system include voltage and current, with the standard current output being a 4-20 mA signal. Understanding these parameters is essential for accurately interpreting the output signal from the transducer.
  • Understanding of rotary potentiometers and their operation
  • Knowledge of voltage and resistance measurement techniques
  • Familiarity with Digital Multimeters (DMM) and their usage
  • Basic concepts of transducer systems and signal outputs
  • Research the operation and applications of rotary potentiometers
  • Learn about voltage output vs. current output in transducer systems
  • Explore the significance of the 4-20 mA current output standard
  • Investigate the role of Digital Multimeters in measuring electrical signals
Electronics engineers, instrumentation specialists, and students studying transducer systems or signal measurement techniques will benefit from this discussion.
StonieJ
If you have a rotary potentiometer that measures the amount of angular displacement, what would you say the output signal of the transducer is? I'm unsure if it's resistance or voltage. A change in angular displacement changes the point of contact within the potentiometer, which directly affects its resistance. However, in our case, we are measuring the change in voltage over the potentiometer with a DMM. Actually, there is a list of parameters we need to figure out, and this is what I've come up with.
Input Signal to Transducer: angular displacement
Output Signal from Transducer: voltage
Output device: DMM
Output of the sensing system: resistance
I'm mainly just confused with the many different types of output. I would think the transducer is the "big picture" (of which our important quantity is voltage), while the sensing system is the potentiometer itself, which changes its resistance. Then I just figured that the output device is whatever your measuring the change with.
You're pretty much correct. Even though the pot. is a variable resistor, you power it so that you get a variable voltage as the actual output signal. The voltage has a lot of benefits, especially if you have to carry that signal over a distance or if you don't have resistance measuring devices.
The two transducer outputs you'll see the most of are voltage and current outputs. The standard current output is a 4-20 mA signal. There are others such as a frequency outputs.
To answer your original question, the output signal is a voltage signal. The signal you actually measure is what that refers to, not the physical "thing" you are measuring, like angular displacement.
It seems like you have a good understanding of the different components involved in this transducer system. The output signal from the transducer is indeed voltage, as this is what is being measured with the DMM. The resistance of the potentiometer is a crucial aspect of the transducer, as it is what is being changed by the angular displacement and ultimately affects the output voltage. The DMM is simply the device used to measure the output voltage, so it can be considered the output device. Overall, it is important to understand the different parameters and components involved in a transducer system in order to accurately interpret and utilize the output signal.
  • · Replies 17 ·
