Special relativity and substitution
The discussion revolves around the application of time dilation in special relativity, specifically in the context of calculating the average speed of a pion based on its decay time and distance traveled. Participants explore the relationship between the pion's lifetime, its motion, and the perspective from which measurements are made.
  • One participant expresses confusion about when to apply the time dilation equation in the context of distance and velocity, questioning the relationship between the pion's rest frame and the observer's frame.
  • Another participant clarifies that the pion's lifetime is measured from the observer's perspective, emphasizing the importance of distinguishing between different reference frames.
  • A third participant introduces a thought experiment involving two observers, discussing how each perceives motion and time dilation relative to one another.
  • Several participants engage in a back-and-forth about how to interpret the measurements of distance and time, particularly regarding the pion's perspective versus the observer's perspective.
  • One participant asserts that the measurements are inherently from the observer's point of view, as pions do not have the means to measure distance themselves.
Participants generally agree that the pion's lifetime must be considered from the observer's perspective, but there is ongoing debate about how to clearly differentiate between the two reference frames and the implications of this for calculations.
There are unresolved questions regarding the interpretation of measurements in different reference frames and the application of time dilation in practical scenarios. The discussion reflects varying levels of understanding about these concepts.
Individuals interested in special relativity, particularly those seeking to understand the implications of time dilation and reference frames in particle physics.
answerseeker
i don't understand when to use substitution as used in the answer to this question:
how fast must a pion be moving, on average, to travel 10m before it decays? average lifetime is 2.6*10^-8.
i know the answer is D=V( to/ sqroot 1-v^2/c^2) but i don't understand why and how to know when to put the time expansion equation into the D=vt equation.
When would u ever do this again, and why isn't the pion's lifetime= t, b/c its at rest.
From the pion's point of view, its at rest, from yours, its not. The question is asking about its lifespan from yours.
Good Quest Answer . Let's say you are person A -- and all you have or can see is light
Then to you light speed is fixed for ever and as far as you know you are at rest ( assuming only you are NOT subject to hidden forces ) . Now we introduce person B .
Assume first off that you cannot see B and he cannot see you -- then you both think you are at rest and just light is speeding around -- But now if you can see each other there are two view points yours and his and you will both judge the other moving by some speed wrt themselves and hence to light . You (A) will apply the correction
to B according to your view of his speed v wrt 'c' so for instance you will say his time slowed or lifetime increased ---- But B will say the same of you .
B ( the pion ) will see the Earth shrink in distance because you and the Earth are seemingly traveling together at v .
In short you always apply the correction but from your viewpoint -- if you wish to put yourself in anothers shoes then you apply it to what THEY see .
Ray.
so how do you know that 10m is from YOUR point of view, not the pion's? since its lifespan is from It's point of view. how do you decipher which goes with who's point of view?
Because YOU were the one who measured it! pions do not carry meter sticks with them!
Every object is at rest "from its own perspective" (ie in its own reference frame). So if something is said to be moving at some nonzero velocity v, you know that must be from the perspective of someone else.
  • · Replies 22 ·
  • · Replies 33 ·
  • · Replies 32 ·
  • · Replies 20 ·
