Why aren't my images appearing in my Java application?
  • Context: Java
  • Thread starter Thread starter Nylex
    Images Java
The discussion revolves around troubleshooting issues related to image display in a Java application, specifically within a JPanel. Participants are exploring potential causes for images not appearing as expected, examining aspects of file paths, working directories, and IDE behavior.
  • Homework-related
  • One participant mentions that the images are not appearing despite the code compiling correctly, indicating a potential issue with file paths.
  • Another participant suggests adding specific lines of code to ensure the images are added to the layout correctly.
  • There is a query about whether the images folder and the .jar file are in the same directory, indicating a possible source of the problem.
  • One participant recommends using an absolute path to check if the issue is related to the working directory.
  • A participant confirms that using an absolute path resolves the issue, prompting further discussion about the working directory's location.
  • There is uncertainty about what constitutes the current directory, with suggestions that it may be the directory of the class file or where the interpreter is run.
  • A new participant shares a similar issue with images not displaying, seeking a solution.
  • Another participant argues that the interpreter's location is not relevant, emphasizing that images must be in the same folder as the classes unless absolute paths are used.
Participants express differing views on the significance of the working directory and how it relates to image loading. There is no consensus on a single solution, as multiple potential causes and fixes are discussed.
Participants mention various IDEs and their behaviors, suggesting that the environment may affect how file paths are resolved. There are unresolved questions regarding the correct directory structure and class naming conventions.
Nylex
Hi, I'm working through the "Building an Application: Part 2: Introduction to Inheritance, Panels, and Layouts" on java.sun.com and the code I've written compiles fine, but the images that are supposed to appear in the JPanel aren't there.
Code:
jl = new JLabel("Java Technology Dive Log", new ImageIcon("images/diveflag.gif"), JLabel.CENTER);
and
Code:
diver = new JLabel("", new ImageIcon("images/diver.jpg"), JLabel.CENTER);
are where images are used.
The image files do exist. They're in a folder called "images", which itself is in a folder named "divelog". The whole code for the file is here, although obviously this class is used in another.
If anyone can help, thanks.
Technology news on Phys.org
Did you add those 3 lines to Welcome.java?
Code:
add(jl, BorderLayout.NORTH);
add(ta, BorderLayout.CENTER);
add(diver, BorderLayout.SOUTH);
Yep, I did.
Do you have your images folder and java .jar file in the same directory?
What .jar file?
I would use an absolute path to double check that is not a working directory problem. That would at least eliminate one possibility.
It works with an absolute path, so what else could be the problem?
Well there you go. Your working directory is not what you think it is !
Why's it not the current directory?!
I believe its usually the directory in which the class file is located, though I could be wrong. Check the documentation on Sun's site: http://java.sun.com.
Will do, thanks :smile:.
Actually I think its the directory in which the interpreter is run. How are you running the interpreter?
I'm using BlueJ. I'll try from the command line and see if that makes any difference.
Edit: I can't run from the command line. I'm getting:
Exception in thread "main" java.lang.NoClassDefFoundError: DiveLog (wrong name:
divelog/DiveLog)
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(Unknown Source)
at java.security.SecureClassLoader.defineClass(Unknown Source)
at java.net.URLClassLoader.defineClass(Unknown Source)
at java.net.URLClassLoader.access$100(Unknown Source)
at java.net.URLClassLoader$1.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
at java.net.URLClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClass(Unknown Source)
at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
when I try "java DiveLog". The class name is DiveLog, so I don't know what the problem is. It works in BlueJ though :confused:.
New to the forum here.
I'm having the same problem with the images not being displayed.
Has anyone figured out the cure?
Mike
The interpreter's location is irrelevant because you can have work-related material in other directories.
A standard IDE for Java such as Eclipse can obviously be in a different location (such as c:\eclipse) and compile things fine from other directories because the compiler KNOWS where to find the standard libraries.
The thing with images is that they have to be in the /same/ folder as your classes, otherwise you have to explicitly define their entire paths.
If it's in a folder, then the folder has to be in the same folder as your main/test class.
If your main class as well as other classes are in let's say, C:\class
then the images should be in C:\class\images\<imageFile>
