Decibel Question (adding I think)
  • Thread starter Thread starter Hit an Apex
The discussion revolves around a problem involving decibel levels produced by machines in a factory, specifically how many identical machines can be added without exceeding a federal limit of 90 dB, given that one machine produces 80 dB. Participants are exploring the relationship between decibels and power ratios, as well as the mathematical implications of sound intensity.
  • Participants are attempting to understand the connection between decibels and power ratios, questioning how to calculate the number of machines that can be added. Some are discussing logarithmic relationships and the implications of decibel increases.
There are various lines of reasoning being explored, including the mathematical relationships involved in decibel calculations and the historical context of the terms used. Some participants have offered insights into logarithmic calculations and power ratios, but no consensus has been reached on a specific approach to the problem.
Participants are navigating the complexities of sound measurement and the specific constraints of the problem, including the federal decibel limit and the nature of the machines involved. There is also mention of prior successful problem-solving experiences, which may influence their confidence in tackling this question.
Hit an Apex
Question at hand, A noisy machine in a factory produces a decibel rating of 80 dB. How many identical machines could you add to the factory without exceeding the 90 dB limit set by federal regulations?
I just did a bunch of other problems regarding h/z and m/s and they were all right :biggrin: , so I don't understand why this program is on webassign. Anyway, 1 machine is producing 80db and I need to figure out how many more machines they can add without going over 90db.
I'd love to know where to start...
What is the connection between Bells and Watts...?
Daniel.
Decibels are measured using common logarithms (except, with a "deci-" prefix, you're actually measuring tenths of a Bel).
The common log of 2 is approximately .301, or, very approximately, .3. That's not a very appealing number, so, by using decibels (tenths of a Bel), we get 3 decibels.
The common log of 10 is 1.0, the common log of 100 is 2.0, the common log of 1000 is 3.0, etc. In decibels, the above would be 10, 20, 30, etc.
Isn't it from A.G.Bell?As Watt from J.Watt?:confused:
Daniel.
Daniel.
Yes, but it's stilled spelled with just one 'l'.
Why, I'm not quite sure. I know a few coorporations donated some vowels to a Eastern European relief effort, due to the scarcity of vowels in the names of Eastern European people. Maybe Bell Telephone Labs made a similar effort to seed the Finnish-Czechoslavakian http://www-linguistics.stanford.edu/Linguistics/Archives/Sesquipedalian/1992-93/msg00006.html .
An increase of 10 dB means that the power ratio in the definition of the dB has to increase by 10. Can you calculate what the power ratio with one machine running is? Do you know what the reference power is?
Or you could simply do the math so its applicable to any level increase.
n * 10^8 = 10^9
This would be in bels (divide by 10 to convert decibels to bels)
Or to show what BobG looks like as a simple bit of math:
2 * 10^8 = 10^8.3
Or you could just do an antilog on the difference too. Like for the number of machiens to result in a 6db increase we have 10^0.6 = 4 times the initial number of machines.
9K
