How Does Torque Affect Angular Velocity in a Falling Block and Wheel System?
The discussion focuses on the relationship between torque and angular velocity in a falling block and wheel system. It establishes that for a bicycle wheel with a moment of inertia I, the angular speed omega_A can be expressed as a function of mass m, gravitational acceleration g, height h, and radius r_A when the block falls. In contrast, when the string is wrapped around a smaller axle of radius r_B, the angular speed omega_B is similarly defined. The consensus is that torque is not necessary for solving this problem; instead, conservation of mechanical energy is the key principle to apply.
  • Understanding of conservation of mechanical energy
  • Familiarity with moment of inertia (I)
  • Basic knowledge of angular velocity and its calculations
  • Concept of gravitational potential energy
  • Study the principles of conservation of mechanical energy in rotational systems
  • Learn how to calculate angular velocity using moment of inertia
  • Explore the relationship between linear and rotational kinetic energy
  • Investigate the effects of different radii on angular speed in pulley systems
Physics students, mechanical engineers, and anyone interested in the dynamics of rotational motion and energy conservation principles.
~angel~
Consider a bicycle wheel that initially is not rotating. A block of mass m is attached to the wheel and is allowed to fall a distance h. Assume that the wheel has a moment of inertia I about its rotation axis.
Consider the case that the string tied to the block is attached to the outside of the wheel, at a radius r_A. Find omega_A, the angular speed of the wheel after the block has fallen a distance h, for this case.
Express omega_A in terms of m, g, h, r_A, and I.
Now consider the case that the string tied to the block is wrapped around a smaller inside axle of the wheel of radius r_B View Figure . Find omega_B, the angular speed of the wheel after the block has fallen a distance h, for this case.
Express omega_B in terms of m, g, h, r_B, and I.
Someone told me that I have incorporate torque into it. I initially thought that you needed to use the conservation of energy, etc. Any help would be great.
You are correct. It is not necessary to consider torque in this problem. You need to use conservation of mechanical energy. The gravitational potential energy of the elevated mass is released as it falls and converted into the linear and rotational kinetic energies of the mass and the wheel, respectively.
Ok...I got the answer. Thanks.
  • · Replies 25 ·
  • · Replies 30 ·
  • · Replies 17 ·
  • · Replies 32 ·
