Calculate the velocity vector as a function of time
The forum discussion focuses on calculating the velocity and acceleration vectors of a plane described by the position functions X = 2.0 - 3.0t and Y = 2.5t². The correct velocity vector as a function of time is v(t) = -3.0i + 5.0tj, and the acceleration vector is a(t) = 5.0j. At t = 2.9 seconds, the magnitude of the velocity is determined to be 14.8 m/s, with a direction slightly below the x-axis. The acceleration remains constant at 5 m/s² in the positive y-direction.
  • Understanding of vector calculus and derivatives
  • Familiarity with kinematic equations in physics
  • Knowledge of Pythagorean theorem for vector magnitude calculation
  • Basic understanding of trigonometric functions for angle determination
  • Study the principles of vector differentiation in physics
  • Learn how to apply the Pythagorean theorem to find vector magnitudes
  • Explore kinematic equations for motion in two dimensions
  • Investigate the relationship between position, velocity, and acceleration vectors
Students and professionals in physics, particularly those studying mechanics, as well as educators looking for practical examples of vector analysis in motion problems.
Tony Zalles
Hi,
Ok I have a bit of difficulty workin this Physics Mechanics problem.
Ok here is the problem...
The coordinates of a plane flying in the xy-plane are given as functions of time by:
X = 2.0m - at
Y = bt^2
where a = 3.0 m/s and b = 2.5 m/s^2
A) Calculate the velocity vector as a function of time.
B) Calculate the acceleration vector as a function of time.
C) Calculate the magnitude and direction of the bird's velocity at t=2.9s.
D) Calculate the magnitude and direction of the bird's acceleration a t=2.9s.
Ok here's what I've accomplished so far...
Code:
                                NOTE:
                    /^          a(x) = a subscript x
    y|             / |          a(y) = a subscript y
     |            /  |             i = unit vector component, x-axis
     |         a /   |             j = unit vector component, y-axis
     |          /    |a(y)j
     |        /θ     |
bt^2 -       *------->
     |         a(x)i
          2.0 - at          x
Now I have these formulas.
Code:
    a = √((a(x))^2 + (a(y))^2)
tan θ = a(y)/a(x)
 a(x) = a cos θ
 a(y) = a sin θ
    a = a(x)i + a(y)j
Ok, now I believe you find a(x) and a(y) by taking the derivatives of bt^2 and 2.0 - at, thus getting 2bt and -a.
But I don't quite understand what the question (part A) is asking, when they want the velocity vector as a function of time.
I'm guessing its this: v(t) = -3.0i + 5.0tj
if this is so then the acceleration vector (part B) is expressed as:
a(t) = 5.0j
So based on this I'm guessing part C is:
v(2.9s) = 5.83 m/s
but I'm not sure if this is correct either since part c asks for 'magnitude and direction', I feel like I'm missing something to my answer...
Lastly following all the above part D should be:
a(2.9s) ≈ 5.0 m/s^2
So...I hope I can get some insight into this problem, I hope someone can help, and give me some guidance.
Thanks.
Your first statement is incorrect. Acceleration is the derivative of velocity. What you are given is the "position" vector.
You know that X= 2.0 - 3.0t and Y = 2.5t^2 which means that the position vector is (2.0- 3.0t)i+ (2.5t^2)j. Differentiate that to get the velocity vector: velocity vector = -3.0 i+ 5.0t j, exactly what you have. The derivative of that is acceleration vector = 5.0j, again, the answer you have.
How did the plane turn into a bird?
At t=2.9, the velocity vector is -3.0i+ 5.0(2.9)j= -3.0i+ 14.5j. The simplest way to calculate the "magnitude" (i.e. speed) is to use the Pythagorean theorem. The length of the vector is √((-3)2+(14.5)2)= 14.8 m/s. Since you don't say how you arrived at "5.83 m/s", I have no idea how you got that. The angle is, as your formula says, tan-1(Vy/Vx)= tan-1(14.5/-3)= tan-1(-4.833)= -0.08, only very very slightly less below the x axis.
The acceleration vector at any time is 5.0j which has magnitude 5 m/s2, which you have (and, by the way, that is exact, not approximate) and direction (which you left out) straight up the y axis.
heh...Thanks for clearin that up, I kinda knew that but now it makes much more sense.
Ok since I'm given, X= 2.0 - 3.0t and Y = 2.5t^2, this is the position vector which is expressed as.
x(t) = (2.0- 3.0t)i + (2.5t^2)j
then: x'(t) = v(t)
then: v'(t) = a(t)
a(t) = 5.0j
woops...yea that was a typo, its still a plane :)
And I guess it would have made more sense if I drew my original diagram as this:
Code:
                                NOTE:
                    /^          v(x) = v subscript x
    y|             / |          v(y) = v subscript y
     |         v /   |             j = unit vector component, y-axis
     |          /    |v(y)j
bt^2 -       *------->
     |         v(x)i
          2.0 - at          x
I only used 'a' as this was the notation used in my textbook I knew it was velocity already.
hey thanks for clarifying what magnitude is.
yea...it was just a careless error on my part I calculated 5.83 m/s by √(-3)^2 + (2.9)^2 instead of √(-3)^2 + (14.5)^2 = 14.8 m/s.
oh yea thanks, so then Part D is:
Acceleration:
direction = 5.0j
magnitude = 5 m/s^2
Ok thanks again, I have a way better grasp on this mechanics stuff now, heh.
  • · Replies 16 ·
