AC Generators: Voltage or Current Source?
The discussion centers around whether an AC generator should be classified as a voltage source, a current source, or neither. Participants explore the operational characteristics of AC generators, including their behavior under varying loads and the implications for power distribution.
  • Some participants suggest that an ideal AC generator can be modeled as a time-varying voltage source, while real generators may include additional resistive elements.
  • Others propose that AC generators function as power sources rather than strictly voltage or current sources, emphasizing the relationship between voltage and current in power transmission.
  • One participant notes that the speed of the generator relates to voltage, while torque relates to current, indicating that constant speed results in constant voltage and varying current with load changes.
  • Another participant highlights that using constant voltage for power distribution minimizes losses compared to constant current, which would lead to varying frequency and operational challenges.
  • There is mention of the implications for synchronous machines, which can operate as either voltage or current sources depending on the context.
Participants express multiple competing views regarding the classification of AC generators, with no consensus reached on whether they are best described as voltage sources, current sources, or power sources.
Participants discuss assumptions related to ideal versus real-world conditions, such as the effects of load resistance on voltage and current, and the operational characteristics of synchronous machines.
infamous_Q
hey I'm wondering whether an ac generator would be classified as a voltage source or current source, or neither (if that's possible)? I'm asking you guys since i have nooooo idea how i would go about determining this. Thanks!
Is this a homework problem? Think about how a generator actually operates: they run at constant rpm, providing constant voltage (voltage is determined by the physical construction of the generator - magnets and windings, etc.) at a constant frequency (determined by the rpm). Current varies as load increases -- but how?
no this isn't a hwk question. this is to satisfy some of my own curiousity. and how? i dunno..thats why I'm askin! lol
hi.
my understanding is that AC power comes in its own voltage/current package. That's why electric companies use transformers, not resisters, to bring down voltage before it gets to your house. assuming we have perfect conductors and blah blah, there is an increase in current proportional to the decrease in voltage. Power (voltage times current) remains constant. So i would consider an AC generator a _power_ source, rather than one of voltage or current. Tesla could probably put it better.
An ideal AC generator would be a time varying voltage source. A real AC generator can adequately be modeled as a time varying voltage source in series with a very small resistor.
It can be either a CCS or a CVS. The speed is related to voltage, and the torque is related to current. Forcing constant torque results in constant current. As the load resistance varies, the voltage varies with it. Forcing constant speed results in constant voltage. As the load resistance changes, current varies inversely.
In real world power transmission, constant voltage is the method employed. Insulators lose much less power than conductors. With constant voltage, to turn off a load, say a lamp, we open a switch and block a voltage source resulting in near zero current. The loss is V^2*G, where G is the conductance of the insulation. If constant current was used, to turn a lamp off, we would close a switch across the lamp shorting it resulting in near zero voltage across it. The loss in this off state is I^2*R, where R is the conductor resistance.
The long and short of it is that V^2*G is much lower than I^2*R. So for now, power is distributed in the constant voltage mode. This is achieved by holding a constant speed, rpm, on the generator. A side benefit to constant voltage operation is constant frequency. The steady 50 or 60 Hz frequency can be employed to make synchronous motors run at a fixed predictable speed. If constant current ac generators were employed, the frequency would vary.
Does this help?
Beat me to it. But yes because a grid will operate at a fixed frequency, the method of generation needs to be a voltage source. Like cabraham said, if it was a current controlled type of generation then the frequency would vary.
As far as an ordinary synchronous machine being a VS or CS, it can go either way.
Voltage = kv * speed
Current = kt * torque (sort of)
  • · Replies 25 ·
