Parallel plates - direction of electric field
The discussion revolves around determining the direction of the electric field between the plates of a parallel plate capacitor in the context of a decreasing magnetic field. Participants are exploring the implications of Lenz's Law and the relationship between induced currents and electric fields.
  • Conceptual clarification, Assumption checking, Mixed
  • Participants discuss the application of Lenz's Law to deduce the direction of the induced current and its effect on the electric field. There are questions about the use of right-hand and left-hand rules in this context, as well as the reasoning behind the direction of the electric field.
The discussion is active, with participants offering insights into the relationship between the changing magnetic field and the induced electric field. Some participants express uncertainty about conventional current versus electron flow, while others confirm the direction of charge accumulation on the capacitor plates.
There is an ongoing exploration of assumptions related to the behavior of electric and magnetic fields, as well as the rules for determining their directions. The discussion reflects a mix of conceptual understanding and practical application of physics principles.
michaelw
Indicate the direction of the electric field between the plates of the parallel plate capacitor shown in the drawing if the magnetic field is decreasing in time. Give your reasoning.
Please help me.. how can i do this?
Try understanding the physics of the situation before asking the question so abruptly---
You would do well to recall Lenz Law... and with it, tell yourself what the direction the induced current in the wire will be (CW or CCW) ? Then decide how that would effect the E field between the capacitor plates.
Oh and might I add... your right hand would most certainly be helpful!
not left hand :/?
Use left hand when dealing with electrons fired thru H fields :D
would the E field be up? (the magnetic field would be decreasing over time, so the induced magnetic field would have to oppsoe the change, and therefore point out of page. the current goes up when magnetic field points out, so the current will create a + charge on lower end of capacitor, - on upper, so E field points up)
current will go CCW right?? (god i hate conventional current)
Hehe, yep you're absolutely right... imagine some unknown entity wishing to fire extra H field upward, since the H field is decreasing... so in using your right hand, you want to point your thumb in the direction of that entity is wishing to fire the H field, and your fingers will naturally curl around in the direction the induced current is traveling... in this case it is CCW like you stated!
So yes, positive charge will accumulate on the bottom plate, and negative on the top... thus creating an E field going from the bottom plate to the top plate--- as for finding the strength of the E field... I doubt you'd be required to ever do that, however you'd analyze using Gauss and apply sigma/2epsilonnaught or whatnot.
  • · Replies 31 ·
  • · Replies 18 ·
  • · Replies 26 ·
  • · Replies 58 ·
