Calculate Molar Mass of Protein from Osmotic Pressure
The discussion revolves around calculating the molar mass of a protein using osmotic pressure measurements. Participants explore the application of the van't Hoff equation in this context, addressing the necessary parameters and assumptions involved in the calculation.
  • Homework-related
  • One participant presents a scenario involving a protein dissolved in water and its measured osmotic pressure, seeking assistance in calculating the molar mass.
  • Another participant questions the initial request for help, prompting clarification on the user's attempts to solve the problem.
  • A participant mentions the use of the equation p = i M R T and expresses uncertainty about the van't Hoff factor (i).
  • Further contributions explain the van't Hoff factor, with examples of its values for different substances, suggesting that for proteins, it is likely 1 since they do not ionize in water.
  • There is a discussion about the nature of the van't Hoff factor, noting that it can be less than expected for compounds that do not completely dissociate.
Participants do not reach a consensus on the exact value of the van't Hoff factor for proteins, although there is a general inclination towards it being 1. The discussion remains open regarding the implications of this factor on the calculation.
Participants do not clarify the assumptions regarding the behavior of the protein in solution or the specific conditions under which the osmotic pressure was measured. There is also no resolution on the exact methodology for calculating the molar mass based on the provided data.
physicsss
To determine the molar mass of a certain protein, 1.00E-3 grams of the protein was dissolved in enough water to make a 1.00 mL solution. The osmotic pressure of this solution was found to be 1.12 torr at 25.0C. Calculate the molar mass of the protein.
Chemistry news on Phys.org
Yes ? And what do you want us to do ?
I assume you want help in working out the molar mass. Where are your attempts first?
The Bob (2004 ©)
I tried using this equation: p = i M R T, but I have no idea what i is.
i = moles of stand-alone stuff per mole of stuff (for lack of better words). for example, i for sulphuric acid is 3. i for potassium chloride is 2. i for acetic acid is 1 (weak acids do not dissociate).
Do you know what it is for protein?
Probably 1
i = van't Hoff factor. Roughly speaking, it measures the degree to which the ions dissassociate in solution. For example, the van't Hoff factor of NaCl is 2 since NaCl completely dissassociatesin water. Since most proteins don't ionize in water, n is probably 1.
i does not necessarily have to be an integer. For compounds that don't completely dissassociate, the van't Hoff factor is less than wht you would expect. The van't Hoff factor for HF for instance, is only a little bit more than 1 and not 2 since HF is a weak acid.
13K
