| Thread Closed |
Energy extraction in power plants |
Share Thread | Thread Tools |
| Apr13-05, 12:34 PM | #1 |
So, I have basically four questions
1) What is the efficiency of converting the heat energy generated by a power plant due to combustion/fusion to electric energy? 2) What are the major ways in which energy is lost while converting it? 3) Is there any way to improve the efficiency? 4) Are their efficient methods to increase the temp. difference so as to increase the Carnot efficiency and therefore the operating efficiency? |
| Apr13-05, 12:48 PM | #2 |
| Apr13-05, 01:18 PM | #3 |
| Apr13-05, 03:34 PM | #4 |
Mentor
An added loss for fission is that it requires two loops of working fluid (so as not to send radioactive water to the cooling towers). This makes the thermodynamic efficiency somewhat lower than a fossil fuel plant.
| Apr13-05, 08:39 PM | #5 |
Also, nuclear plants are often restricted from using very high temperatures or pressures in their steam cycles, for safety reasons. It's not a direct inefficiency, but it means that Carnot cannot be improved this way.
| Apr16-05, 12:26 PM | #6 |
Some things to add to these good answers:
-Maybe the most efficient power plants for electricity generation are the Combinated Cycle ones (using a compound of Brayton+Rankine cycle). Its efficiency reaches 50%. -There is a limit in the efficiencies of power plants: the 2nd principle or Carnot theorem. None power plant can surpass the efficiency of a Carnot engine. - I think the main problem is transform the fuel chemical energy to thermal energy. This kind of conversions are coupled with a loose of availability due to the 2nd principle. There are some machines, as Hydrogen Cells which directly converts chemical energy into work without loosing availability. |
| Apr16-05, 08:54 PM | #7 |
Admin
Back in the 1970's there were plans for at least 8 advanced High-Temperature Gas Cooled Reactors in the US, and the efficiencies of those plants was targeted in the range 39-42%, due to high temperatures of the He-cooled, graphite-moderated core. None of the plants were built, and the only gas cooled reactor in commercial operation - Ft. St. Vrain (Colorado) had significant technical problems (http://fsv.homestead.com/FSVHistory.html). Coal/oil plants can operate at much higher temperatures and pressure (superheat), and so their efficiencies can be in the mid-to-upper 30's%. The most efficient plants to date are combined-cycle plants which operate with an aero-derivative gas-fired turbine (Brayton cycle) with a steam cycle using the exhaust heat of the gas turbine. The gas turbine efficiency is about 42-45%, and the steam cycle gets about 30-33% of the exhaust for a total efficiency of about 62%. For additional info on congen plants - see http://www.poweronsite.org/Tutorial/Cogeneration.htm Some basics on thermodynamic cycles - https://wrc.navair-rdte.navy.mil/war...rmo/thermo.htm Improvements have been made in steam turbine blade design - see the Olkiluoto-3 (EPR) thread - which enable more efficient thermal to mechanical conversion without increasing Thot. Similarly, the manufacturers of aeroderivative turbines (e.g. GE, Siemens, Alsthom) have greatly improved efficiencies of compressors and gas turbines, so system efficiencies have also improved. http://www.gepower.com/prod_serv/pro...le/library.htm Siemens bought the Westinghouse gas turbine business, IIRC, and ABB may have sold their turbine business as well. http://www.siemenswestinghouse.com/e...item/index.cfm |
| Apr17-05, 11:53 AM | #8 |
Thank you for the replies. BTW, what do you think of Tesla turbines in comparision to the conventional ones? I heard that they are much more effective.
| Thread Closed |
| Thread Tools | |
Similar Threads for: Energy extraction in power plants
| Power plants | Engineering, Comp Sci, & Technology Homework | 0 | ||
| Microwave Power Plants | General Physics | 4 | ||
| The Sun and Nuclear Power Plants | Biology, Chemistry & Other Homework | 3 | ||
| Desalination from power plants | Earth | 0 | ||
| Nuclear Power Plants | Nuclear Engineering | 3 | ||
