Work problem, deals with great pyramid
The discussion focuses on calculating the volume of the Great Pyramid of Cheops, which stands 410 feet tall and has a base area of 755 feet square, using calculus. The volume is determined by integrating the volume of each slab from 0 to 410 feet. Additionally, the work done against gravity in constructing the pyramid involves calculating the weight of each differential mass element, factoring in the stone's density of 200 lb/ft³, and applying the formula for work done, mgh.
  • Understanding of calculus, specifically integration techniques
  • Familiarity with volume calculations of geometric shapes
  • Knowledge of physics concepts related to work and force
  • Basic understanding of density and its applications in physics
  • Study integration techniques for calculating volumes of solids of revolution
  • Learn about the relationship between density, mass, and volume in physics
  • Explore the concept of work done against gravity in various contexts
  • Review examples of calculus applications in real-world engineering problems
Students studying calculus and physics, particularly those interested in applications of integration and work calculations in engineering contexts.
stangeroo
this is a calc problem, but I thought it fits better here than in the math section since its homework.
Here it goes:
the great pyramid of cheops is 410 feet tall and 755 feet square at the base. find the volume of the pyramid using calculus.
Part two:
The stone used in constructing it has a density of 200lb/ft^3. Find the work against gravity in building the pyramid.
I understand you integrate from 0 to 410 of the volume of each slab with a thickness of deltaX(or would it be delta y?) I am unsure how to calculate part two though, i haven't had much experience with work and force. anyone want to drop a hint or two :smile:
You're right on the first part, and it doesn't matter what you call the integration variable. For the second part, the work done raising a mass m by a height h against a gravitational acceleration g is mgh. Add up the work done on each differential mass element ρdV, where ρ is the density.
For each horizontal slice, its area, its volume, and its weight can all be expressed as functions of y (distance from the x-axis). And for each slice, the work done is equal to the weight times the height.
  • · Replies 20 ·
  • · Replies 20 ·
42K
9K
