Calculate Force on Small Gear from Torque with Pully and Shaft
The discussion focuses on calculating the force exerted on a small gear from torque applied via a pulley and shaft system. A pulley with a radius of 0.2 m applies a force of 0.01 N, resulting in a torque of 0.002 Nm. This torque is transferred to a small gear with a radius of 0.01 m, leading to a calculated force of 0.2 N on the gear. The method used, applying the torque equation (T = Fr), is confirmed to be correct, demonstrating that smaller radius gears experience greater forces to maintain the same torque.
  • Understanding of torque calculations (T = Fr)
  • Basic knowledge of pulley systems
  • Familiarity with gear mechanics
  • Concept of force and radius relationship in rotational systems
  • Study advanced torque calculations in mechanical systems
  • Learn about gear ratios and their impact on force transmission
  • Explore pulley system designs and their applications
  • Investigate the effects of friction in gear and pulley systems
Mechanical engineers, physics students, and anyone involved in designing or analyzing mechanical systems involving gears and pulleys.
Physics_wiz
A pully with radius .2 m is fixed on a shaft and on the other end there's a gear with radius .01 m. If a force of .01 N pulls down on the pully, what's the force on the tip of the small gear?
Here's my work:
The force produces a torque about the shaft T = Fr = (.01 N)(.2 m)= .002 Nm
The small gear is subjected to the same torque so T = Fr again,
.002 Nm = (F2) (.01 m)
F2 = .2 N
I know this is a simple problem, but I have to make sure I did it right because it's part of a bigger problem. So, did I do it right?
Yeah, i think so
Yes, you have correctly calculated the force on the tip of the small gear. Your method of using the torque equation (T=Fr) to find the force is correct. Since the small gear has a smaller radius than the pulley, it will experience a larger force to produce the same torque. This is because torque is the product of force and distance, and since the distance (radius) is smaller for the small gear, the force must be larger to achieve the same torque. Overall, your calculation is correct and you can use this method for similar problems in the future.
  • · Replies 42 ·
  • · Replies 25 ·
  • · Replies 21 ·
