cyberdeathreaper
- 46
Here's the question:
The needle on a broken car spedometer is free to swing, and bounces perfectly off the pins at either end, so that if you give it a flick it is equally likely to come to rest at any angle between 0 and [itex]\pi[/itex].
Consider the x-coordinate of the needle point - that is, the "shadow," or "projection," of the needle on the horizontal line.
What is the probability density [itex]\rho(x)[/itex] if r is the length of the needle?
Conceptually, I'm trying to clarify the following:
In a previous question, they asked to find [itex]\rho(\theta)[/itex], which I found as simply [itex]\frac{1}_{\pi}[/itex]. This implies the theta-derived answer moves the x coordinate from r to -r as [itex]\theta[/itex] goes from 0 to [itex]\pi[/itex].
In calculating the probability for this question, I assumed x moved in the same fashion (ie, x goes from r at [itex]\theta = 0[/itex] to -r at [itex]\theta = \pi[/itex]). This reverse movement gives a probability density that is always negative.
My question is, is this possible? The total probability does equal 1 if I move from right to left, though I'm not sure if this is permissible.
Likewise, could I simply change the sign from negative to positive for the probability density, only reasoning that if x moves left to right, the signs should be reversed?
