lawtonfogle
- 159
First I called it an idea, not a theory. One might call it an hypothesis, though I do not think it is at that stage. I have posted it so someone who works on demminsions can help see it, maybe test it.
To start off with, the string theory says that there must be 11 deminsions. I know this is only one, but I read it was the most excepted one.
We have 4 deminsions. The first one is used to draw lines, the second is used to draw 2D pictures, the third is used to make 3D objects, the forth is the one that 'animates' these objects. Using one of the first three and the forth, it is possible to make a moving line.
This part becomes hard, because i envision pictures. Envision a 3D graph, now put a sphere in it. Now envision a set of ten graphs, in which the sphere becomes a cube. The direction the graphs go in is the flow of time, or the 5th deminsion. If we have 2 deminsions to the 'flow of time', we can cause time to lope. The second deminsion of the 'flow of time' is 6th deminsion. Now just add a third deminsion so the 'flow of time' can not only loop, but move to a new 'time line'. This would be the 7th deminsion.
As I said, this might be hard, because I cannot make you see what I see in my head.
Now the idea for a 8th deminsion is the turning of the graph, so that it could form one of the special loops (the one with one twist, giving it one side that can be traced all the way around twice, I forgot its name
). This idea for the 8th deminsion is way out there, but i tried to make the others ones make more sence, and when i have a better math and physics background, ill try to put math behind it.
