RMS Derivation of Piecewise Sinusiodal Function
The forum discussion focuses on calculating the root mean square (RMS) of a piecewise sinusoidal function defined as v(t) with specific intervals. The user initially derives the RMS formula as Vrms = Vm - Vm*SQRT(1/pi*(theta-sin(theta)*cos(theta))) but recognizes an error when evaluating at theta = pi, where the expected result is Vrms = Vm/SQRT(2). The conversation highlights the importance of correctly defining the function's domain and the implications of integrating over specific intervals to achieve accurate RMS values.
  • Understanding of root mean square (RMS) calculations
  • Familiarity with piecewise functions in mathematics
  • Knowledge of integral calculus and its applications
  • Basic concepts of sinusoidal functions and their properties
  • Review the derivation of RMS for piecewise functions
  • Study the properties of sinusoidal functions and their integrals
  • Learn about the implications of domain extension in piecewise functions
  • Explore numerical methods for verifying integral calculations
Mathematicians, electrical engineers, and students studying signal processing or waveform analysis will benefit from this discussion, particularly those interested in RMS calculations of non-continuous functions.
j0shha1nes
Calculate the root, mean, square of v(t) where
v(t) = 0 0 < wt <= theta
v(t) = Vm*sin(wt) theta < wt <= pi()
v(t) = 0 pi() < wt <= pi()+theta
v(t) = Vm*sin(wt) pi()+theta < wt <= 2*pi()
In integral form, I am confident that it looks like this.
Vrms = SQRT(1/T*INTEGRAL(Vm^2*sin^2(wt)dt)) from theta/w to pi/w AND pi+theta/w to 2*pi/w
I believe it integrates like this. My thought was that I could integrate only one of the ranges and then double my answer due to symmetry in the sinusoidal function.
Vrms = Vm*SQRT(w/2*pi*(t/2-sin(2wt)/4w)) evaluated from theta/w to pi/w
After substitions and simplification (which I have been over about 10-15 times) I get this.
I know this is wrong because when I evaluate this equation at theta = pi, the value is zero. The correct value is Vrms = Vm/SQRT(2) when theta = pi. I have either defined the problem wrong somehow or I have performed the integral wrong.
Many thanks for any help.
It appears to me that when theta = pi you should get zero. You have extended the domain of the V(t) = 0 function to the entire interval. Vrms = Vm/SQRT(2) should be the result for theta = 0. Your result does not appear to be giving that, but I'll let you check it. Check also at theta = pi/2. At that point your integral should be half the result for theta = 0 (assuming I'm right above), so Vrms = Vm/2.
Thanks for the reply.
Not sure what you mean when you say that the domain of v(t) = 0 has been extended ?to the entire interval? (confusing part between the question marks). v(t) equal zero only for a fraction of the first half cycle (and second half cycle) of the T period (0 to 2pi radians).
I will check some of the other quadrants that you mentioned. I have not done that yet. Here they are.
Vrms(theta=pi/2) = Vm*(1-1/sqrt(2))
Vrms(theta=3pi/2) = Vm*(1/sqrt(2)-1)
One thing that I keep running into that I do not understand is that the RMS value over the entire period of an alternating signal should not be zero. I expect it to be an increasing function, not linearly, but always increasing as theta varied from 0 to 2pi radians. I would expect this even when there are equal positive and negative area(s) under the curve. Do you agree?
  • · Replies 29 ·
  • · Replies 16 ·
  • · Replies 24 ·
