Find Thrust of Rocket: 1.9x10^3 kg with 2.5x10^3 m/s
  • Thread starter Thread starter recon
    Rocket Thrust
The problem involves calculating the thrust of a rocket based on its mass, the speed of ejected gas, and the rate of fuel consumption. The context is rooted in dynamics and the principles of momentum and thrust in rocket propulsion.
  • Mixed
  • The original poster attempts to apply the thrust equation involving mass flow rate and velocity of ejected gas. Some participants question the clarity of the approach, particularly regarding the mixing of terms related to acceleration and velocity.
There is a mix of agreement on the expression for thrust, but also significant questioning of the methodology used to derive it. Some participants are exploring alternative derivations and seeking additional resources for practice.
One participant expresses unfamiliarity with problems involving changing mass and momentum, indicating a potential gap in foundational understanding. There is also a reference to homework rules regarding the sharing of solutions and derivations.
recon
A space-research rocket stands vertically on its launching pad. Prior to ignition, the mass of the rocket and its fuel is 1.9 X 103 kg. On ignition, gas is ejected from the rocket at a speed of 2.5 X 103 m/s relative to the rocket, and fuel is consumed at a constant rate of 7.4 kg/s. Find the thrust of the rocket.
Can someone please check my solution?
Let the mass of both the rocket and fuel be m, and let T be the thrust. Let 'a' be the acceleration of the rocket, and g be the acceleration due to gravity. Then,
[tex]T = \frac{d(mv)}{dt}[/tex]
[tex]T = m\frac{dv}{dt} + v\frac{dm}{dt}[/tex]
[tex]T = 7.4 kgs^{-1} \times 2.5 \times 10^3 ms^{-1}[/tex]
[tex]T = 19.5 \times 10^3 N[/tex]
Looks good to me.
I'm quite unfamiliar with problems involving a rate of change of momentum brought about by a rate of change of mass. In fact, this is the only problem of its kind that I've come across in my book.
Can someone please direct me to an online source of problems of this kind? I need more practise, thanks.
You might want to look at the following thread:
https://www.physicsforums.com/showthread.php?t=72176
Note that you are mixing together the rocket's acceleration [tex]a=dv/dt[/tex] while using "v" as the speed of the ejected fuel, relative to the rocket.
This is meaningless.
Although you get the right expression for the thrust (i.e, the force acting upon the rocket from the ejected fuel), your method of derivation is totally wrong.
now, the way by which i derive the rocket equation in post 4 is one way.
Later on in that thread, I'll derive it slightly differently, relying heavily upon Newton's 3.law (i.e, by relating the momentum change experienced by an ejected particle to the force acting upon it from the rocket system).
If you would be so kind to post your comments here, rather than in the thread in question, I would be grateful.
(Possibly, the thread will be made into a sticky later on, as a homework help thread)
  • · Replies 42 ·
  • · Replies 22 ·
  • · Replies 16 ·
9K
