Expressing Natural Numbers as Sum of Primes
The discussion centers around the possibility of expressing all natural numbers greater than 2 as the sum of N unique prime numbers. Participants explore various aspects of this topic, including definitions of primes, related conjectures, and the implications of including the numbers 1 and 2 in the sums.
  • Some participants question whether all natural numbers greater than 2 can be expressed as the sum of unique primes, citing examples and counterexamples.
  • There is a discussion about the inclusion of 1 in the sums, with some arguing that it changes the nature of the problem since 1 is not a prime.
  • One participant references Russell's postulate and suggests a method for expressing even and odd integers as sums of primes.
  • Another participant mentions the strong Goldbach conjecture, which asserts that all positive even integers can be expressed as the sum of two primes, raising questions about the proof status of this conjecture.
  • Historical references are made to Schnirelman's result, which states that every even number can be expressed as the sum of no more than 300,000 primes.
  • There is a discussion about the implications of Bertrand's postulate and its relation to the existence of primes within certain ranges.
  • Some participants express uncertainty about the relevance and strength of certain mathematical results related to primes.
Participants do not reach a consensus on whether all natural numbers greater than 2 can be expressed as the sum of unique primes, and multiple competing views remain regarding the definitions and implications of including non-prime numbers in the sums.
There are unresolved assumptions regarding the definitions of primes and the inclusion of numbers like 1 and 2 in the sums. The discussion also touches on various conjectures and the strength of mathematical results without reaching definitive conclusions.
metrictensor
Is it possible to express all natural numbers greater than 2 as the sum of N unique prime numbers? For example, 6 = 2 + 3 and 18 = 13 + 5.
6=2+3 does it?
What about the smallest natural greater than 2 that isn't a prime? isn't that a counter example too?
matt grime said:
6=2+3 does it?
I forgot to mention that 1 and 2 can be used in the sum. I made a mistake. Not 6 = 2 + 3, 5 = 2 + 3. Once you define 1 and 2 you get 3. From 3+1 you get 4 and so on. 5=2+3...
So you are NOT talking about a "sum of primes" because 1 is not prime.
Now I'm a little perplexed. 2 is a prime. Anyway, the result follows quite easily from Russell's postulate:
For every n>1 there is a prime number p such that n<p<2n.
So, given m an integer, if it is even pick an prime in the range m/2 to m, and if it is odd pick a prime in the range (m+1)/2 to m+1, call this prime p(1).
Then m-p(1) < m/2, and we proceed by indcuction - the next prime we pick must be distinct from p(1) since it must be less than m/2, and p(1) is greater than m/2.
We just need to show how to write the sum for "small m" to get the full proof, ie m=1,2,3 which yo'uve done.
Matt grime: the result follows quite easily from Russell's postulate.
Yeah? As re-expressed by Euler, an equivalent form of this conjecture (called the "strong" or "binary" Goldbach conjecture) asserts that all positive even integers can be expressed as the sum of two primes.http://mathworld.wolfram.com/GoldbachConjecture.html
So you are saying the Goldbach Conjecture has been proven?
Schnirelman (1939) proved that every even number can be written as the sum of not more than 300 000 primes (Dunham 1990)
What if we added up the first 300 002 primes?
What is that supposed to mean :rolleyes: ?
Nevermind.
Of course not, but the OP didn't ask for the sum of TWO primes, he asked for the sum to be expressed as *some* sum of N distinct primes, allowing for 1 to be included.
The possibly dodgy assumption I made was that it wasn't supposed to be a fixed N, which seems reasonable, given the other hidden assumptions in the post, after all it would be required that N=1 or 2 otherwise, which we know to be false and bloody hard respectively.
Well, whatever it should be called, it states given any natural n greater than 2 there is a prime p satisfying n<p<2n, or similar.
It has been proved there exists a prime for any natural number n > 2 there exists a prime (and I'm really dragging this one from memory) p such that:
[tex]n - n^{\frac{23}{42}} < p < n[/tex]
Which is quite a bit stronger :smile:. Although I'm not sure how useful.
Here's the formula on the Wolfram site
http://functions.wolfram.com/NumberTheoryFunctions/Prime/29/0003/
  • · Replies 17 ·
  • · Replies 19 ·
  • · Replies 17 ·
  • · Replies 21 ·
  • · Replies 24 ·
