Help visualizing this problem O.o Heat Prob
  • Thread starter Thread starter Seiya
    Heat
The minimum volume of the reservoir tank required for a hot-water heating system can be calculated using the formula for the volume of a cylinder, V = πr²h, where the inside radius (r) of the copper pipe is 9.15 x 10-3 m and the length (h) is 52.1 m. The calculated volume of the pipe is 8.42 x 10-3 m3. To account for thermal expansion when the water temperature increases from 24.9 °C to 65.4 °C, the overflow volume must also be considered, which can be calculated using the formula V = m x ΔT x β, where m is the mass of the water and β is the volumetric thermal expansion coefficient of water. Combining these volumes provides the minimum reservoir tank volume needed to prevent overflow.
  • Understanding of the volume of a cylinder formula (V = πr²h)
  • Knowledge of thermal expansion concepts
  • Familiarity with basic physics principles related to heat transfer
  • Ability to perform calculations involving temperature changes
  • Research the volumetric thermal expansion coefficient of water
  • Learn about the properties of copper as a material in heating systems
  • Explore advanced calculations for thermal expansion in fluid systems
  • Study the design considerations for hot-water heating systems
Engineers, HVAC professionals, and students studying thermodynamics or fluid mechanics who are involved in the design and analysis of hot-water heating systems.
Seiya
Many hot-water heating systems have a reservoir tank connected directly to the pipeline, so as to allow for expansion when the water becomes hot. The heating system of a house has 52.1 m of copper pipe whose inside radius is 9.15 x 10- 3 m. When the water and pipe are heated from 24.9 to 65.4 °C, what must be the minimum volume of the reservoir tank to hold the overflow of water?
My prob: I know the 52.1m of copper pipe and the radius should give me a volume somehow so then i can solve the problem but i got no idea what this looks like :(
Doing this on stupid egrade thing from wiley... i already messed up one problem for hurrying (got the right answer after submitting the incorrect one :( ) so i can't mess this one up... any help would be greatly appreciated!
Answer: The minimum volume of the reservoir tank required to hold the overflow of water can be calculated using the equation for the volume of a cylinder, V = πr2h, where r is the radius of the pipe and h is the length of the pipe. With r = 9.15 x 10-3 m and h = 52.1 m, the minimum volume of the reservoir tank is 8.42 x 10-3 m3.
First, let's visualize the problem by breaking it down into smaller parts. The hot-water heating system in the house has a reservoir tank connected directly to the pipeline. This means that the tank is connected to the pipe and acts as a storage unit for the hot water. The purpose of the tank is to allow for expansion of the water as it becomes hot, preventing any damage to the pipeline.
Next, we are given the length of the copper pipe (52.1m) and its inside radius (9.15 x 10^-3m). This information allows us to calculate the volume of the pipe using the formula V = πr^2h, where r is the radius and h is the length. This volume represents the maximum amount of water that can be held in the pipe without any expansion.
Now, we need to find the minimum volume of the reservoir tank to hold the overflow of water when the temperature of the water and pipe increases from 24.9 to 65.4 °C. This means that the water will expand and the excess water will flow into the reservoir tank. To calculate the volume of the overflow, we can use the formula V = m x ΔT x β, where m is the mass of the water, ΔT is the change in temperature, and β is the volumetric thermal expansion coefficient of water.
Finally, we can combine the two volumes (maximum volume of the pipe and overflow volume) to determine the minimum volume of the reservoir tank needed. This can be done by adding the two volumes together. The resulting volume will be the minimum volume of the reservoir tank required to hold the overflow of water when the temperature increases from 24.9 to 65.4 °C.
I hope this helps in visualizing the problem and approaching it step by step. Remember to always double check your calculations and take your time to avoid making mistakes. Best of luck with your egrade!
