Proving the Convergence of a Math Function: A Step-by-Step Analysis
  • Thread starter Thread starter broegger
    Analysis
The discussion revolves around proving the convergence of the function f(x) = ∑(1/(x²+n²)) as x approaches infinity. Participants are exploring the behavior of this infinite series and its limit as x tends to infinity.
  • Participants are examining the limit of the function as x approaches infinity and questioning the validity of certain assumptions regarding convergence. There are discussions about the behavior of finite sums and the implications of the inequality provided in the original post.
The discussion is ongoing, with various participants offering insights and critiques of each other's reasoning. Some have provided observations about the function's behavior based on graphical analysis, while others are questioning the assumptions made regarding the limits and the role of N in the analysis.
There are mentions of computational tools like Maple and Mathematica, which return different results, leading to confusion about the convergence of the series. Participants are also grappling with the implications of the terms in the series and their dependence on N.
broegger
Hi,
I have to show that the function
[tex]f(x) = \sum_{n=1}^{\infty}\frac1{x^2+n^2}[/tex]​
tends to 0 as [tex]x \rightarrow \infty[/tex], i.e. [tex]\lim_{x\rightarrow\infty}f(x) = 0[/tex]. How can I do this?
There is a hint that says I should use the inequality [tex]f(x) \leq \sum_{n=1}^N\tfrac1{x^2+n^2} + \sum_{n=N+1}^\infty\tfrac1{n^2}[/tex]. It is obvious that the first term approaches 0 as [tex]x \rightarrow \infty[/tex], but what about the second term?
How do you know that?
[tex]\lim_{x\rightarrow +\infty}\sum_{n=1}^{N}\frac{1}{x^{2}+n^{2}}=? 0[/tex]
My Maple says it's undefined,as well as the initial limit...
Daniel.
Denote the initial limit by [itex]F =:\lim_{x\rightarrow +\infty} f(x)[/itex]
U can show that [itex]f(0)=\zeta\left(2\right)=\frac{\pi^{2}}{6}[/itex] and [itex]\forall x\in\mathbb{R}, f(x)\leq f(0)[/itex].
Daniel.
I've looked at the graph and the function quicky goes to 0 as "x" increases.
It's continuous everywhere on [itex]\mathbb{R}[/itex] and has the derivative
[tex]f'(x)=\sum_{n=1}^{\infty}\left(-\frac{2x}{\left(x^{2}+n^{2}\right)^{2}}\right)[/tex]
which is negative on the positive semiaxis.Therefore the function decreases continuously on the positive semiaxis.Since it's continuous,even and strictly positive,the asymptotic limits have to be zero.
Looking forward for critique.
Daniel.
It's a function of N.
(Notice that f(x) is not a function of N...)
Why wouldn't the asymptotic limit be 1/10, or π4/792?
You know what, I would give a whole dollar if someone could explain to me why:
[tex]\sum_{n=1}^{\infty}\frac{1}{a^2+n^2}=\frac{a\pi Coth[a\pi]-1}{2a^2}[/tex]
This is what Mathematica returns and I don't wish to suggest using Mathemtaica to prove things but I don't know how to prove the original question, and in my attempts to learn how, I've reduced it to the above. Now, you know what happens to the RHS as a goes to infinity right?
Interesting.My ancient version of Maple returned a difference of psi functions of complex arguments multiplied with 1/(ix).
Daniel.
I can let N -> infinity and thereby make the second term vanish but then what about the first term which also depends on N?
It's a finite sum.
Hey in response to your question, I have observed that it's very easy to tell that the sum tends to 0 as n goes to infinity. As n^2 gets large, the x^2 term gets very large too at the same rate. Any # with an inreasing denominator decreases in value, therefore the total sum goes to zero. :smile:
"n" is not what is tending to infinity here. "x" is, as far as I can see. But even it it were n doing the increasing, the following still makes no sense:
Why? How does the value of n affect x in any way?
  • · Replies 21 ·
