How to Determine the Center of Mass for a Parabolic Sheet Metal?
The discussion centers around determining the center of mass of a parabolic sheet metal, specifically defined by the equation y=ax^2, with y ranging from 0 to b. Participants are tasked with finding the center of mass in terms of parameters a and b, starting with the area calculation.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss various methods for calculating the area and center of mass, questioning the correct evaluation of the area and the expression for dm. There are attempts to clarify the meaning of "weighted" in the context of the center of mass calculation and the implications of constant density.
The discussion is active, with multiple participants exploring different interpretations and methods for calculating the center of mass. Some participants express uncertainty about the correctness of their integrals and the assumptions made, while others provide insights into the integration process and the relationship between mass and area.
There is a lack of consensus on the final answer, with participants arriving at different results (3b/4 and 3b/5) and questioning the validity of the book's answer. The discussion also highlights potential confusion regarding the integration limits and the setup of the problem.
hbomb
I am having the hardest time figuring out the center of mass of this problem.
A sheet of metal is cut in the shape of a parabola (imagine that you have a parabola shape with the top being flat). The curved edge of the sheet is specified by the equation y=ax^2, and y ranges from 0 to b. Find the center of mass in terms of a and b. (You will need to find the area first.)
There's the question. The answer is 3b/5. I used center of mass equation
Ycm=(1/m)(integral of y dm)
The formula for y_cm looks good. What r u using for "dm"?
dm
at first i had (3M)/(ab^3)ydx
then i found the area a different way and i came up with (Mx^3)ydx/(2ab)
what is the correct evaulation of this area. this dm is the most important part of the integration.
The width of the metal sheet at distance y is 2*Sqrt(y/a). Intergate this from 0 to b to get the area,
BTW, what is "M"?
Did you get it?
I find 3b/4.
M comes from this
Total mass (M) / Total Area (the integration of the function) = dm (tiny portion of mass) / da (tiny portion of area)
M/A=dm/da
i just solved for dm so i could then substitute in for dm when i find the center of mass
That is just saying the density is constant i think. Anyway u don't need the density. Were u able to get the area?
quasar987: do u get 3b/4 for the final answer or for area or what? hbombs first post says its 3b/5
could you show me the steps of how you arrived to this answer
maybe the answer in the book is wrong.
i doubt the book is wrong. First find the area, that is compute the integal
integral from 0 to b of (2*sqrt(y/a)) dy = Area
then compute the integral of y "weighted" by mass, or area in this case
integral from 0 to b of (2*sqrt(y/a)*y)dy
and divide what u get by the area...
What does "weighted" means?
According to the dm you found, the integral we want to compute is
[tex]Y_{CM} = \iint\frac{y}{A}dA[/tex]
So I found A. HackaB's way it the shortest:
[tex]A = \int_0^b2\sqrt{\frac{y}{a}}dy = \frac{4b}{3}\sqrt{\frac{b}{a}}[/tex]
So
[tex]Y_{CM} = \frac{3}{4b}\sqrt{\frac{a}{b}}\int_{-\sqrt{b/a}}^{\sqrt{b/a}}\int_0^b ydydx = \frac{3}{4}b[/tex]
what i meant by weighted is this: when u compute the center of mass of an ojbect, u are finding the average position "weighted" by how much mass is at a given position. In this prob., we know the center o mass is on the y-axis by symmetry so we just have to find the "weighted average" of y. The amount of mass at distance y above the x-axis is dm = 2*sqrt(y/a)*dy. Actuallly this is da...area...but we can take density to be 1 because it will cancel anyway. So what you need is
integral of y dm = integral of 2*y*sqrt(y/a)*dy from 0 to b. For this I get (4/5) * b^(5/2) / sqrt(a). Divide this by what quasar987 gave for A to get the answer.
Could you tell me what is wrong with my method? How is the integral I evaluated not the right one? Isn't it the integral of y/A over the surface of the parabola?
hbomb,
I get 3b/5
I turned the parabola on its side so the new function is:
y = (x/a)^1/2
then I integrated (Xcm - x)*y*dx from 0 to b, set the integral to zero and solved for Xcm.
this
should be
[tex]Y_{CM} = \frac{3}{4b}\sqrt{\frac{a}{b}}\int_0^b\int_{-\sqrt{y/a}}^{\sqrt{y/a}} ydxdy = \frac{3}{5}b[/tex]
add: u were integrating over a rectangle
HackaB said:
this
should be
HAHAHA. ooook. :-p
It could have been
[tex]Y_{CM} = \frac{3}{4b}\sqrt{\frac{a}{b}}\int_{-\sqrt{b/a}}^{\sqrt{b/a}}\int_{ax^2}^b ydydx = \frac{3}{4}b[/tex]
too... which is what I tought I was doing.
quasar987 could you show me how you arrive at getting the stuff before the integral sign and the logic behind the two integrals, thanks.
  • · Replies 21 ·
  • · Replies 57 ·
