Range of Validity for Maclaurin Expansion of ln(1-x)
  • Context: Undergrad
  • Thread starter Thread starter josephcollins
    Range
The range of convergence for the Maclaurin expansion of ln(1-x) is established as -1 < x < 1. This conclusion is derived using the ratio test, which confirms that the series converges for any x within this interval. The Maclaurin series is expressed as ln(1-x) = -x - (x^2)/2 - (x^3)/3 - (x^4)/4 - ..., and it is uniformly convergent within its radius of convergence. This method can be applied to determine the convergence of other Maclaurin and Taylor series as well.
  • Understanding of power series and their properties
  • Familiarity with the ratio test for convergence
  • Basic knowledge of Maclaurin and Taylor series
  • Concept of uniform convergence in series
  • Study the ratio test in detail for series convergence
  • Explore the derivation and applications of Taylor series
  • Investigate the concept of uniform convergence in mathematical analysis
  • Practice finding the range of convergence for various power series
Students of calculus, mathematicians, and educators seeking to deepen their understanding of series convergence, particularly in the context of Maclaurin and Taylor expansions.
josephcollins
Hi ppl. May I ask how you obtain the range of convergence for the maclaurin expansion of ln(1-x) and taylor's series, maclaurin's in general? Thanks, Joe
A power series is uniformly convergent everywhere inside its radius of convergence, so you just need to find that. The ratio and root tests are good bets.
Hi Joe,
The Maclaurin expansion of ln(1-x) is given by:
This expansion is valid for values of x within the range of convergence, which is -1 < x < 1. This means that the series will converge to the exact value of ln(1-x) for any value of x within this range.
To determine the range of convergence for this series, we can use the ratio test. This test states that if the limit of the absolute value of the ratio of consecutive terms is less than 1, then the series will converge.
In this case, we have:
lim(n->∞) |(x^n)/(n)| = lim(n->∞) |x^n| = |x|
Since we want this limit to be less than 1, we need to have |x| < 1, which gives us the range of convergence as -1 < x < 1.
This same process can be applied to find the range of convergence for any Maclaurin or Taylor series. It is important to note that the range of convergence can vary for different series, so it is necessary to check each individually.
I hope this helps answer your question. Let me know if you have any further questions.
  • · Replies 19 ·
  • · Replies 22 ·
