Understanding Moment of Inertia: Solving a Loop-the-Loop Problem"
The discussion centers on the moment of inertia of a solid sphere in a loop-the-loop problem, specifically when rolling on a "V" track. The moment of inertia remains (2/5)*M*r^2, as it is calculated about the center of mass, despite the sphere rolling on a different radius (r'). The torque applied by the track is indeed smaller due to the reduced radius, affecting the condition for rolling without slipping. The angular velocity formula provided, [(2)^0.5*v]/r, is confirmed to be correct.
  • Understanding of moment of inertia, specifically for solid spheres
  • Knowledge of torque and its relationship to radius in rotational dynamics
  • Familiarity with the concepts of rolling motion and conditions for rolling without slipping
  • Basic principles of mechanical and rotational energy conservation
  • Study the derivation of moment of inertia for various shapes, including solid spheres
  • Learn about torque calculations in rotational dynamics, focusing on varying radii
  • Explore the conditions for rolling without slipping in different scenarios
  • Investigate the relationship between translational and rotational kinetic energy in rolling objects
Physics students, mechanical engineers, and anyone interested in the dynamics of rolling motion and rotational mechanics.
Frod
Hello, I have been given a loop-the-loop problem to do. Now the problem I have isn't with conservation of mechanical or rotational energy, it's with the moment of inertia of the solid sphere. Usually it would be (2/5)*M*r^2 however the sphere is rolling on a "V" track (see image). I get the correct answer if I leave the moment of inertia as (2/5)*M*r^2, however, shouldn't it be different as it is no longer rolling on r, instead it is rolling on r' (see image)?
I have worked out that the angular velocity will be [(2)^0.5*v]/r, where r is the radius of the sphere and v the velocity of the sphere. Any help would be greatly appreciated. Thank you.
Frod.
Frod,
If I understand this problem (and I'm not sure I do) the moment of inertia of inertia of the sphere doesn't change, but the torque on the sphere does, because it's applied at a smaller radius.
The fact that the ball makes contact with the track at a smaller distance from the axis of rotation does not change anything. The ball is still rotating about an axis through its center of mass, and the moment of inertia of a ball about any axis through its CM is what you said, (2/5)*M*R^2. In this way, the motion of the ball can be separated neatly into two parts: 1) translation of the center of mass, and 2) rotation about an axis through the CM. The total kinetic energy is the sum of kinetic energies associated with the two motions.
edit: what jdavel says is true, the torque applied by the track is smaller. What this means in terms of calculation is that your condition for rolling without slipping will take into account the smaller radius. So I shouldn't have said that it doesn't change ANYTHING. Your answer for angular velocity looks good.
  • · Replies 138 ·
9K
  • · Replies 69 ·
  • · Replies 30 ·
  • · Replies 49 ·
