What is the change in density if the water is heated to 85oC?
The change in density of water when heated from 4°C to 85°C can be calculated using the coefficient of volume expansion, α, which is 2.10x10-6/°C. The initial density of water at 4°C is 1.00x103 kg/m3. By applying the formula Δρ = -αρΔT, where ΔT is the temperature change (81°C), the change in density (Δρ) can be determined. The final density can then be calculated by subtracting Δρ from the initial density.
  • Understanding of thermal expansion concepts
  • Familiarity with density calculations
  • Knowledge of basic algebra for manipulating equations
  • Ability to work with scientific notation
  • Study the principles of thermal expansion in fluids
  • Learn how to apply the coefficient of volume expansion in real-world scenarios
  • Explore density calculations for different states of matter
  • Investigate the effects of temperature on the properties of water
Students in physics or engineering, scientists studying fluid dynamics, and anyone interested in the thermal properties of water.
Jayhawk1
Here's the problem:
The density of water at 4oC is 1.00x103kg/m3. What is the change in density if the water is heated to 85oC? Remember that the change will be the final density minus the initial density. Assume a coefficient of volume expansion of 2.10x10-6/oC.
Now, I have tried using a standard mass of 1000KG and solving the problem that way, however I am way off... please help
Jayhawk1 said:
Here's the problem:
SOLUTION HINTS:
By definition:
{Coefficient of Volume Thermal Expansion} = α = (-1/ρ)(Δρ/ΔT)
::: ⇒ Δρ = -αρΔT
Use values given in problem statement for terms on the right to calculate "Δρ".
Jayhawk1 said:
Here's the problem:
Calculate the volume expansion assuming an initial volume V_0. Add that to the initial volume to find a final volume. Multiply the initial density times V_0 to get an initial mass expressed in terms of V_0. Divide that mass by the new volume. The V_0 factors will all divide out. It will work.
