Solving MATLAB ODE with Matrix Coefficients: Help Requested
  • Context: MATLAB
  • Thread starter Thread starter christy
    Matlab Ode
The discussion focuses on solving a second-order ordinary differential equation (ODE) in MATLAB using matrix coefficients. The user presents a system defined by matrices A and G, and seeks guidance on implementing a numerical solution using the forward Euler method. Key insights include defining a combined state vector y and utilizing MATLAB's ODE solver, ode45, for numerical integration. The conversation emphasizes two approaches: solving a large system as a single vector or breaking it down into individual equations for each variable.
  • Understanding of MATLAB programming and syntax
  • Familiarity with numerical methods for ODEs, specifically the forward Euler method
  • Knowledge of matrix operations and linear algebra concepts
  • Experience with MATLAB's ode45 function for solving differential equations
  • Explore MATLAB's documentation on the ode45 function for advanced usage
  • Learn about implementing the Runge-Kutta methods for ODE solving
  • Investigate matrix manipulation techniques in MATLAB for efficient computation
  • Study the stability and convergence of numerical methods for ODEs
This discussion is beneficial for MATLAB users, particularly engineers and scientists working on numerical simulations of dynamic systems, as well as students learning about differential equations and numerical analysis.
christy
Hi,
I have tried everything to figure this out in MATLAB and I can't so I was wondering if anyone could help me please.
I have a 2nd order linear system that I reduced to 1st order such that
q = dz/dt
and A.(dq/dt) = Gq(t) + f(t)
where A and G are matrices...I can't figure out how to solve this in MATLAB with having matrix coefficients. Can someone please give me some hints?
A and G are generated matrices and are constant for this problem.
Thanks
You can solve systems of equations and systems of systems of equations the same way.
If q is size N x 1, and z is size N x 1, then define
y = [q; z] which is size 2N x 1
Using a simple forward Euler scheme,
y[n+1] = y[n] + dt*[f1(q,z,t(n)) ; f2(q,z,t(n))]
where f2 = q[n] and f1 = inv(A)*(G*q[n] + f(tn))
G is size N x N, q is N x 1, and f is N x 1, so [f1; f2] is size 2N x 1, just like y. So all the sizes work fine. You're just solving one really big system. Then you can make some operator C which is size 1 x N to pick out the ouput you want, like z_1(t), or whatever.
Alternatively, you could keep the two equations separate and solve
q[n+1] = q[n] + dt*inv(A)*(G*q[n] + f(tn))
and
z[n+1] = z[n] + dt*(q[n])
Now you're solving two systems, each size N x 1.
If you still don't like that, you can break up q and z into N equations each.
Since q = [q_1; q_2; q_3;...;q_N], you can write it as
q_1[n+1] = q_1[n]+dt*((inv(A)*G)(1,:)*q[n]+inv(A)f_1(tn))
q_2[n+1] = q_2[n]+dt*((inv(A)*G)(2,:)*q[n]+inv(A)f_2(tn))
and do the same for z to get 2N individual equations to solve.
So the bottom line is, you can either stick all of your equations, each of which may be working on a vector, into one giant vector and solve that, or you can break it up into any number of equations and solve them all individually stepping through time.
Dear all,
I have a equation that goes like this...
d^2/dt^2[x] + f(t) x - gamma * d/dt [x] where f(t) is a function of t. I have a numerical form of f(t), but no analytical form, so i want to pass this whole vector into my function...but I am able to pass only a single value...My program is as follows,
Main.m
clear all
close all;
clc;
s1 = input('Input File name without any *.txt extention :','s');
input_file_name = [s1 '.txt'];
Data=load(input_file_name); % column vector
time = Data(:,1)'; % Convert to row vecor
init = [0,0.5*2*pi]; % Initial condition
f =1.42E27*Data(:,2); % f(t) -- only numerical form is available
[t,y]=ode45(@eqn,time,init,[],f); % If u remove f from here and write this as %exp(-t/2E-12) inside the fun eqn.m, then, it works
plot(t,y(:,1))
eqn.m
function rk = eqn(t,y,f)
gamma= 2*pi*0.1E12;
rk = [y(2); - (f y(1)) -gamma*y(2)];
Could anyone help me out to solve this problem...
with best regards
kamaraju
