Torque, Force, magnetic moment ()
The discussion revolves around a problem involving a rectangular coil in a magnetic field, specifically focusing on calculating the force on each side of the coil, the magnetic moment, and the torque acting on the coil. The coil has 16 turns, with specified dimensions and orientations relative to the magnetic field.
  • Participants discuss the initial steps for calculating the force on a current-carrying wire in a magnetic field, with some expressing uncertainty about how to begin. There are attempts to apply the formula for force and considerations about the number of turns in the coil. Questions arise regarding the angles involved and the need to calculate forces for each side of the coil individually.
Some participants have provided guidance on how to approach the problem, suggesting that understanding the magnetic moment is crucial for calculating torque. There is acknowledgment of the complexity due to multiple sides of the coil and the number of turns, indicating a productive exploration of the problem.
Participants note the importance of a diagram to visualize the problem, as well as the need to clarify the angles between the coil sides and the magnetic field. There is an emphasis on the order of calculations and the relationships between force, magnetic moment, and torque.
EvaBugs
I'm not sure I know how to start this problem.
"A rectangular coil has 16 turns and sides of length a=20 cm and c=50 cm. The coil is pivoted around the y-axis and its plane is at 30 degrees to a magnetic field B=50 k T. The current is 10 A
a)Find the force on each side
b)what is the magnetic moment of the coil?
c)What is the torque on the coil? "
How do I start this problem? I really have no idea
You start by learning how to find the force on a current carying wire in a magnetic field. Find that and post it and we can take it from there.
I know that F=IL x B = ILB sin 30 where I=10 L=20 and B = 50
Am I on the right track?
Yes. That is a good start. Now think about how many turns of wire are carrying that current, and the fact that there are four different straight-line segments of the loop.
So, I'd have to find the force on each side individually.
For the first side:
F1 = 10A (0.2 m) i X 50 k ?
Am I supposed to find the values of B (in the i and j direction)?
So, to find the torque, I do:
Torque = N(IAB sin 90)
Once I have that, I can find the magnetic dipole moment using:
Torque= u x B ?
For the first side:
I assume you have a diagram to go with this problem, so you know which side of the coil is which, and I assume from your reply here that the two 20cm sides make the angle of 30 degrees with B. The 50cm sides make a different angle with B. You are on the right track with the first force, but there are 4 of them, and don't forget about the 16 turns. What does that do?
Torque= u x B ?
There is a reason why part b) was asked before part a) The magnetic moment (magnetic dipole moment) of the loop is a property of the geometry of the loop and the current it carries. The torque depends on that magnetic moment, so the moment is in fact included in the equation for the torque. You would have to know how torque depends on the moment to do things in the order of c) then b), which of course can be done if you understand where the torque equation comes from. I suggest you do b) then c) and find out how to calculate the moment directly from the porperties of the coil.
Thank for your help. I think I have figured it out
  • · Replies 25 ·
