Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Mathematics > Linear & Abstract Algebra
Notices
Reply
image nullspace Share It Thread Tools Search this Thread image
Old Apr27-05, 10:23 AM       Last edited by EvLer; Apr27-05 at 10:25 AM..            #1
EvLer
EvLer is Offline:
nullspace
Hello everyone,
it's final's time next week , so I will be posting here more often than usual
Here is one problem I came across when doing review:
The nullspace of non-zero 4x4 matrix cannot contain a set of 4 lin. indep. vectors. (T/F)
The way I was thinking is that if I solve a homogeneous s-m with this matrix, and if the dimension of nullspace is 4, that means that there have to be 4 free variables in the homogeneous s-m, but matrix is just 4x4.
And then there is this rank-nullity theorem that n = rank(A) + nullity(A), so in this case rank(A) = 0, is it ever possible? My guess is not.
Does the same hold for dim of nullspace (nullity): it has to have at least one solution (trivial, where everyting = 0, but that does not mean that the nullity is an empty set!) ?
Is it correct?
Thanks in advance!
Old Apr27-05, 10:39 AM                  #2
Galileo
Galileo's Avatar
Galileo is Offline:
Recognitions:
Homework Helper Homework Helper
Have you learnt what bases are? If you have 4 linearly independent (nonzero) vectors, they form a basis for the space. The action of the matrix on any vector in your space is determined by the action on the 4 basis-vectors.
What does that mean for Av (A = matrix, v=vector), where v is any vector.
Ofcourse, the rank equation works fine too. What can you conclude from A if its rank is zero?
Old Apr27-05, 10:48 AM                  #3
EvLer
EvLer is Offline:
Yeah, I know about bases. And this part I understand.
this is a bit blurry.
I can't say it's non-existent, but if it's rank = 0, dimens. of rowspace = 0!
Even if all the rows/cols are lin. dep. rank would be at least 1.
But if it's zero I dunno, it cannot be zero-vector, since it's one of the conditions. That's why ask.
n = dimesion of nullspace? but then what
Old Apr27-05, 11:20 AM                  #4
Data
Data is Offline:
Precisely. The rank of a non-zero matrix is never zero (the ONLY vector space of dimension zero is the set containing only the zero vector, and its "basis" is the empty set). Thus if you find that null(A)=4 => rank(A)=0, you've answered the question.
Old Apr27-05, 11:33 AM                  #5
HallsofIvy
PF Mentor
HallsofIvy is Offline:
Equivalently: a 4 by 4 matrix maps vectors from R4 to R4- which is 4 dimensional. The null space of any linear operator (or matrix) is a subspace of the domain space (here R4). If it contains 4 linearly independent vectors the its dimension is at least 4. In fact, the only 4 dimensional subspace of R4 is R4 itself. Saying the null space contains 4 independent vectors is simply saying the null space is R4 itself: the matrix maps every vector into the 0 vector and so is the 0 matrix.
Old Apr27-05, 11:44 AM                  #6
EvLer
EvLer is Offline:
Thanks!
Then a follow-up question: does nullity has to be at least 1? since it always has a solution as zero-vector? Which I assume to be non-empty, so it's 1.
On one hand it makes sense as I described it above, on the other hand, it doesn't: by rank-nullity thm that would mean that matrix contains at least one lin. dep. row/col: n = rank(A) + nullity(A).
But looking at a matrix A with all cols/rows lin. indep: rank(A) = n, which would mean nullity(A) = 0.
Is it a contradiction? Or am I missing something?
Thanks again.
Old Apr27-05, 11:55 AM                  #7
Data
Data is Offline:
The nullity of a matrix is the dimension of the nullspace of the matrix. The nullspace of any matrix contains the zero vector. In the case that the nullspace is the zero vector (and only in this case), the nullity of the matrix is 0, because (as I mentioned in my last post), the dimension of the vector space containing only the zero vector is zero (a basis for the vector space has zero elements - ie. the basis is the empty set).
image image
Reply
Thread Tools
Similar Threads for: nullspace
Thread Thread Starter Forum Replies Last Post
Entries in every row add to zero... (nullspace/determinant question!) mace2 Linear & Abstract Algebra 2 Apr9-08 06:58 AM
Finding the basis of the nullspace, can you see if i'm doing this right? mr_coffee Calculus & Beyond 2 Dec6-05 04:35 PM
nullspace(kernel) and transpose complexhuman Linear & Abstract Algebra 1 Oct24-05 02:22 AM
(LINALG) : Nullspace of transpose : N(A^T) FrogPad Introductory Physics 1 Apr19-05 01:25 AM
Nullspace and Column Space Question Bouchart Linear & Abstract Algebra 2 Nov22-04 05:21 AM
Powered by vBulletin Copyright ©2000 - 2010, Jelsoft Enterprises Ltd. © 2010 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
