Proofs in Linear Algebra: Countable Sets, Algebraic Numbers, and Fields
This discussion focuses on proofs in Linear Algebra concerning countable sets, algebraic numbers, and fields. It establishes that any linear well-order on a countable set C is induced from the canonical order on natural numbers N via a bijection. Additionally, it proves that all algebraic numbers form a countable subfield of the complex numbers C and discusses the representation of the ring C[[x]] as an inverse limit of finite-dimensional rings over C. Lastly, it confirms that the field Qp, the field of fractions of Zp, is uncountable through a surjection onto the non-negative reals.
  • Understanding of countable sets and bijections
  • Familiarity with algebraic numbers and polynomial roots
  • Knowledge of rings and fields in abstract algebra
  • Concept of inverse limits in ring theory
  • Study the properties of countable sets and their bijections
  • Learn about algebraic numbers and their significance in field theory
  • Explore the construction of rings and fields, focusing on finite-dimensional representations
  • Investigate the field Qp and its applications in number theory
Mathematicians, students of abstract algebra, and anyone interested in advanced topics in Linear Algebra and field theory.
blaster
Linear Algebra proof
I would appreciate any help with any of the foolowing:
1. Let C be a countable set. Prove that any linear well-ordered on C with the property that whatever c in C there are only finitely elements c` with c`<c, is unduced from the canonical order on N via a bijection N-> C. (N - natural no)
2. Prove that all algebraic numbers (all roots of polynomials with rational coefficients) form a countable subfield of C (complex).
3. Find a representation of the ring C[[x]] as an inverse limit of rings which have finite dimension over C.(complex).
4. Prove that the field Qp is uncountable. (Qp=field of fractions of Zp)
Number 4 is straight forward. You just need a surjection onto the reals (well in this case the non-negative reals which are also uncountable).
Hint. Given a number p any real number can be written in the form [tex]\sum_{j=n}^\infty a_j p^{-j}[/tex] with [tex]0 \le a_j < p[/tex] for some [tex]n\in \mathbb{Z}[/tex]. Do you know any representations of Qp that is similar? The surjection doesn't not need any homomorphic properties.
Easier than a diagonal argument. Though there is also a diagonal argument.
1. To prove that any linear well-ordered on C with the given property is induced from the canonical order on N via a bijection, we need to show that there exists a bijection f: N -> C such that for any two elements n, m in N, n < m if and only if f(n) < f(m) in C.
First, we know that C is countable, which means that there exists a bijection g: N -> C. Let's define a new function h: N -> C such that h(n) = g(n+1). This function essentially shifts the elements of C by one, so that the first element of C is now mapped to the second element, the second element to the third, and so on.
Next, let's define a new function f: N -> C such that f(n) = g(1) if n = 0, and f(n) = h(n-1) if n > 0. This function essentially maps the first element of N to the first element of C, and then maps the remaining elements of N to the remaining elements of C in the same order.
Now, let's consider any two elements n, m in N. If n < m, then we know that f(n) = h(n-1) < h(m-1) = f(m) in C, since h is a bijection. And if f(n) < f(m) in C, then we can easily see that n < m, since f(n) = g(1) if n = 0, and f(n) = h(n-1) if n > 0.
Therefore, we have shown that there exists a bijection f: N -> C such that for any two elements n, m in N, n < m if and only if f(n) < f(m) in C. This proves that the linear well-order on C is induced from the canonical order on N via a bijection, as desired.
2. To prove that all algebraic numbers form a countable subfield of C, we first need to show that the set of all polynomials with rational coefficients is countable. This is because each polynomial can be represented as a finite sequence of rational coefficients, and the set of all finite sequences of rational numbers is countable.
Next, we know that the set of all roots of a polynomial with rational coefficients is finite. This
  • · Replies 28 ·
