How Do You Solve This Related Rates Problem Involving Two Cars and a Pulley?
The problem involves related rates concerning two cars connected by a rope over a pulley. The scenario describes the movement of the cars in relation to a fixed point on the ground and requires determining the rate at which one car is moving towards that point based on the rate of movement of the other car.
  • Participants discuss the relationship between the distances of the cars from the fixed point and how to express these in terms of each other. There is an exploration of the derivatives involved and the application of the chain rule.
Participants are actively questioning the relationships and derivatives involved in the problem. Some have offered guidance on focusing on the constant sum of the hypotenuses and the relationships between the rates of change. There is a recognition of potential errors in the application of derivatives, but no consensus on a final approach has been reached.
There is an emphasis on ensuring correct application of the chain rule and maintaining clarity in the relationships between the variables involved. Participants are preparing for an exam, which may influence the urgency and depth of the discussion.
ktpr2
Im going through odd number related rate problems in preparation for an exam tmmrw. The correct answer is [tex]\frac{10}{\sqrt{133}}[/tex]. There is something wrong with the relation I construct; first the problem:
Two cars A and B are connected by a rope 39 ft long that passes over a pulley P. The point Q is on the floor 12 ft directly beneath P and between the carts. Cart A is being pulled away from Q at a speed of 2 ft/s. How fast is cart B moving towards Q at the instant when cart A is 5 ft from Q?
The diagram they give is similar to an isocelles triangle with PQ running 12 ft down the middle. Point A is on the left, point B is on the right, representing carts A and B respectively.
I figure they want me to find [tex]\frac{dB}{dt} = \frac{dB}{dA} \frac{dA}{dt}[/tex] So i expressed point QB in terms of QA and got [tex]\sqrt{ (39-\sqrt{QA^2+144})^2-144}[/tex]. However this taking the deriviative of this times 2ft/s does not yeild the correct answer. What would be the correct way to relate QB in terms of QA?
You have two right triangles sharing a common leg, with the sum of their hypotenuses constant at 39 feet. You need to work out the relationship between the lengths of the remaining two legs. It appears you know that, but have lost track of something somewhere. You need not solve for B in terms of A. Just take advantage of the fact that AP + BP is constant and find d(BQ)/dt in terms of d(BP)/dt and d(AQ)/dt in terms of d(AP)/dt. How are d(AP)/dt and d(BP)/dt related?
well, then, I could solve for B in terms of A? Does that just mean that my work above is incorrect? Or that [tex]\frac{dB}{dt} = \frac{dB}{dA} \frac{dA}{dt}[/tex] is incorrect? I'm trying to find my conceptual flaw.
Your expression for QB appears to be correct, and the chain rule is correct. Perhaps taking a derivative that is a bit complicated is where you are going wrong, or maybe its finding the length of QB. I have some numbers worked out. What are you getting for QB and for the answer?
Your expression is right. I get the answer. Just be extra careful when taking the derivative.
ahhh... I made the silly mistake of taking [tex]\frac{dA}{dB} \frac{dA}{dt}[/tex], not [tex]\frac{dB}{dt} = \frac{dB}{dA} \frac{dA}{dt}[/tex] thank you both for your assistence.
12K
12K
