Ferric Chloride: MSDS and safety precautions
  • Thread starter Thread starter enigma
    Safety
The discussion revolves around the safety precautions necessary when handling Ferric Chloride, particularly in the context of its use for applications such as etching printed circuit boards. Participants explore various safety measures based on Material Safety Data Sheets (MSDS) and personal experiences.
  • One participant suggests that Ferric Chloride is not very dangerous, noting a health hazard rating of 2, and recommends gloves, goggles, and an apron.
  • Another participant points out that Ferric Chloride is very corrosive and advises working in a hood and avoiding skin contact and inhalation of vapors.
  • A participant shares a personal anecdote about staining from Ferric Chloride and emphasizes the importance of using gloves and avoiding contact with skin and clothing.
  • Common safety practices are reiterated, including wearing gloves and goggles, being cautious with handling, and considering the use of a fume hood.
  • Some participants mention the potential for skin irritation and the need for eye protection, while others express that they have not experienced significant issues when handling the compound.
  • There is a suggestion to consult a chemical disposal service for excess material, with a caution against using sodium carbonate for inactivation due to the mess it can create.
Participants generally agree on the necessity of gloves and eye protection, but there is some disagreement regarding the level of precaution required, such as the use of masks and fume hoods. The discussion reflects a range of personal experiences and interpretations of safety guidelines.
There are varying interpretations of the safety data, with some participants emphasizing the corrosive nature of Ferric Chloride while others downplay its dangers. The discussion also highlights the importance of individual sensitivity to chemicals.
This discussion may be useful for individuals working with Ferric Chloride in laboratory settings, particularly those involved in PCB etching or similar applications, as well as those seeking to understand safety precautions related to chemical handling.
enigma
Staff Emeritus
Hi all,
I have an application where I'm going to need to be using Ferric Chloride ( http://www.sciencestuff.com/msds/C1731.html ).
Unfortunately, the guy who told me what I needed to use is now out of town, and out of communication so I'm not able to ask him what a reasonable level of safety precautions are needed.
Am I going to just need gloves?
Gloves and air filter?
Gas mask?
Hood?
Full bunny suit?
Can someone take pity on this dumb aerospace engineer and help me make sense of the MSDS?
-thanks
Chemistry news on Phys.org
I would say it isn't that dangerous of a material to work with. The health hazard is only a 2. Many of the common solvents people work with like hexanes, acetonitrile, and DCM are a lot worse for you to be exposed to. Its not flammable or very reactive so I would say wear gloves (you should always no matter what chemical you are working with), goggles/safety glasses, apron or lab coat and you should be fine. Just don't expose the compound to a lot of light, since it decomposes to HCl which could potentially be dangerous.
Actually I just looked up a MSDS for it at JTBaker http://www.jtbaker.com/msds/englishhtml/f1060.htm
This one lists the contact rating and says it is very corrosive, so you will want to be more cautious than I originally thought. Just work in the hood, avoid contact w/ skin and try not to breathe in any vapors it gives off (which will be HCl gas most likely).
Yes, it is corrosive so don't get it on your skin: use gloves. Don't get it on your clothes either: it will make nasty staines. My bf got it on his pants, it did not burn any holes.. but now the black pant has a brown stain :-p
I am not sure what the best way is to inactivate the material. Do you have a chemical disposal service? You should give any excess to them. By bf read on the internet to put soda (sodium carbonate) in it.. I would not do that: it makes a biiggg mess (giant souffle).
In dealing with chemicals, the rules of thumb are pretty much the same, except for exceptional cases.
Wear gloves, goggles, be careful in handling the solution (try not to spill it), wear shoes and long pants, much of it is common sense. The MSDS seems to suggest the use of a fume hood...although I don't quite remember such measures when handling this compound in lab.
Be sure to follow up on the sheet in case any contact should occur. It might also be safe to wear masks in this case, although this may be a bit excessive...try not to breathe the vapor.
Thanks all!
I'm guessing this is for etching PCBs. Ferric chloride is relatively harmless...just make sure you've got gloves on, and keep in mind the it is a good dye, so don't spill.
I've used FeCl3 for etching printed-circuit boards. It's acidic (salt of a strong acid & weak base) and can cause skin irritation, but I never had any problems when it got on me (some people are more sensitive). You should wear eye protection, though.
  • · Replies 130 ·
51K
  • · Replies 21 ·
  • · Replies 16 ·
  • Sticky
  • · Replies 48 ·
71K
