How can I prove the invertibility of a diagonalizable matrix?
  • Context: Undergrad
  • Thread starter Thread starter randommacuser
    Matrix Proof
The discussion revolves around the conditions for the invertibility of a diagonalizable matrix, exploring the relationship between diagonalizability, eigenvalues, and the span of column vectors in Rn. Participants examine proofs and counterexamples related to these concepts.
  • Some participants propose that if an nxn matrix A is diagonalizable, its columns span Rn, suggesting that proving this involves showing the rank of A equals n.
  • Others argue that a matrix does not need to be invertible to be diagonalizable, raising questions about the implications for determinants of diagonal matrices.
  • A participant questions the relationship between the determinant of a diagonal matrix and its eigenvalues, noting that if A is not invertible, then det(A) could be zero while det(D) cannot be.
  • Some participants discuss the conditions under which a diagonalizable matrix is invertible, suggesting that it is invertible if and only if all its eigenvalues are nonzero.
  • There is confusion regarding the invertibility of the matrix of eigenvectors Q and its implications for diagonalizability.
Participants express differing views on the relationship between diagonalizability and invertibility, with some asserting that diagonalizability does not imply invertibility, while others explore conditions under which a diagonalizable matrix can be invertible. The discussion remains unresolved regarding the implications of these relationships.
Participants highlight that the definitions and properties of diagonalizable matrices and their eigenvalues may depend on specific assumptions, such as the invertibility of the matrix of eigenvectors. There are unresolved questions about the implications of these definitions on the determinants of the matrices involved.
randommacuser
How do I prove that if an nxn matrix A is diagonalizable (is invertible, has rank n, etc.), its columns span Rn?
To prove that columns span Rn, you just need to find the basis of the column-space: reduce the matrix and see if the rank = n, i.e. there has to be n linearly indep. columns, which is very easy to see if the matrix is reduced. Then the basis is the columns of the original matrix, not the columns of the reduced form.
Also, for invertible matrix A, det(A) != 0 (not equal to zero).
Don't know how much that helps.
If A is a matrix with rank n, its column vectors are independent and form a basis, so every vector can be written as a lin. comb. of them. In other words, these vectors span the entire space.
Equivalently, recall that Ax (x some vector in Rn) is a linear combination of the column vectors of A, so Ax=b has a solution if and only if b is in the span of the the column vectors of A.
If A is invertible, the equation [itex]Ax=b[/itex] has a solution for every vector b (namely [itex]x=A^{-1}b[/itex]) so the column vectors span Rn.
A matrix doesn't have to be invertible to be diagonalizable...
Ohh, yeah :eek:
Thanks for pointing that out! At first I was confused by your remark. I had to prove it to myself.
But here's the thing that now bothers me:
given:
A is a matrix, Q - matrix of its eigenvectors, Q' - inverse of Q, D - matrix containing eigenvalues of A by diagonal.
So A is diagonilazable iff A = QDQ'.
Then let's say I take determinant of both sides like so:
det(A) = det(QDQ')
Then det(A) = det(D), since det(QQ') = 1.
But if, as you pointed out, A is not invertible necessarily, then det(A) = 0 but det(D) cannot be = 0!
What am I missing here? It is not supposed to contradict each other :redface:
Why can't the determinant of a Diagonal matrix be zero?
this
although I see your point, because eigenvalue can be 0, while eigenvector cannot. I am still confused :confused: though, because it is defined exactly the same way in my text-book as well, i.e. Q has to be invertible.
Is the 0 matrix diagonalizable? Invertible? Once you've answered these, can you guess at the link (and even better, you can try to prove your conjecture!) between diagonalizability and invertibility?
EvLer said:
this
So what, why is this confusing, what's that link got to do with what I wrote? At no point does it state either A or D are invertible, indeed A is invertible if and only if D is.
Was working on conjecture as Data suggested. Came to same conclusion (yooo-hooo, it worked!)
Thanks for confirming it :smile:
P.S. Oh, anwering your question: I think I've read it wrong, I thought you said that Q does not have to be invertible. Anyway, sorry for confusion and thanks much again.
or, equivalently you can say that a diagonalizable matrix is invertible iff all its eigenvalues are nonzero. This can, in fact, be generalized too.
