What Happens When a Spinning Object's Radius Becomes Zero?
  • Context: Undergrad
  • Thread starter Thread starter aviator
    Radius Spinning
The discussion revolves around the hypothetical scenario of what occurs when the radius of a spinning object approaches zero. Participants explore concepts related to rotational and translational motion, energy conservation, and the mechanics involved in altering the radius of the object.
  • Exploratory, Debate/contested, Conceptual clarification
  • One participant suggests that as the radius approaches zero, the object would begin to rotate around its axis to conserve kinetic energy, implying a transformation from translational to rotational motion.
  • Another participant questions the feasibility of reducing the radius significantly, indicating that considerable effort would be required to achieve such a change.
  • A different viewpoint proposes that if the object is initially given a speed of 100 m/s, it could maintain that speed indefinitely under the conservation of energy, assuming no friction, while suggesting a mechanism involving gearing to facilitate this transformation.
  • One participant challenges the practicality of the proposed gearing mechanism, urging the original poster to reconsider their assumptions and consult physics literature.
Participants express differing views on the feasibility and implications of reducing the radius of a spinning object, with no consensus reached on the correctness of the claims made.
The discussion includes assumptions about energy conservation and the mechanics of gearing, which may not be fully explored or defined. The practicality of the proposed scenarios remains uncertain.
aviator
my educated guess is that with 0 radius the object would start rotating around the axe to keep the kinetic energy
this would mean a transformation of translation into rotation
am i correct?
:smile:
First off you had to do a heck of a lot of work to reduce the radius.
not really if you crank the spinning with the pulling by gearing the axe with the radius bar
you apport a initial speed of 100 m/s to the object and according conservation of energy the object should keep those 100 m/s for ever (neglecting friction)
the bar radius would be geared with the axe transforming the spinning into pulling
i don't care how you gear it you have a lot of work to do.
Please take a break from your wild imagination and go find a physics book.
  • · Replies 17 ·
  • · Replies 23 ·
  • · Replies 39 ·
