A question on air pressure & altitude
The discussion revolves around the effects of altitude on air pressure in relation to compressed air supply hoses. Participants explore how changes in external air pressure at different altitudes impact the internal pressure of a sealed compressed air system, particularly focusing on whether the stress on hoses would increase proportionally with altitude changes.
  • One participant notes that the absolute air pressure decreases from 14.696 psi at sea level to 10.91 psi at 8000 feet, suggesting a 25% reduction in external pressure.
  • Another participant emphasizes the need to clarify whether the pressure discussed is gauge or absolute, indicating that gauge pressure would maintain the same net effect on hose wall stress.
  • A different perspective argues that the stress induced in the hose is a function of internal pressure alone, independent of external atmospheric conditions.
  • Further clarification is provided regarding the characteristics of the hose and whether it can handle the same internal pressure at altitude, questioning if the internal pressure would effectively increase to 125 psi due to reduced external pressure.
  • One participant asserts that if the system is sealed at 100 psi gauge at sea level, the pressure at 8000 feet would be 103.786 psig, not a proportional increase, and explains the relationship between absolute and gauge pressure.
Participants express differing views on how altitude affects the pressure in a sealed system, with some asserting that the internal pressure remains constant while others suggest it could be perceived differently due to changes in external pressure. The discussion remains unresolved regarding the implications for hose stress.
There are assumptions about the behavior of gases under varying temperatures and the specific characteristics of the hoses that are not fully explored. The discussion also relies on the definitions of gauge versus absolute pressure, which may lead to different interpretations of the problem.
This discussion may be of interest to engineers, technicians, and students involved in fluid dynamics, mechanical engineering, or those working with compressed air systems in varying altitudes.
Dave-h
Good afternoon Ladies & Gents,
A question about the effect of air pressure on compressed air supply hoses.
On the web site: http://www.engineeringtoolbox.com/air-altitude-pressure-25_462.html the absolute air pressure at 0 feet and 8000 feet, are given as 14.696 and 10.91 psi respectively - a reduction of around 25% when moving from sea level to 8000 feet.
If a compressed air system that operates at 100psi at sea level, is taken to 8000 feet, would the connecting air hoses be experiencing the stress equivalent to 125psi at sea level?
Thanks
Dave
First of all you have to specify whether it is gauge pressure or absolute pressure. If it is gauge pressure then net effect(the difference of internal and external pressures) on hose wall remains same.
If it is absolute pressure, then there is a difference of (14.696-10.91) = 3.786psig (higher at higher altitude)
Regards,
In terms of simply the stresses induced due to the pressure in the tube/pipe, no. Since you would undoubtedly be talking about 100 psig. The age old [tex]\sigma = (P*R)/t[/tex] does not involve a difference in pressure, simply the internal. The stress induced due to pressure is a function of the material. Think of a beam being bent in a vacuum. The stresses on that would be no different that if it were done in some other atmosphere.
Thank you both for your replies.
Perhaps a little more explanation on my part would have helped.
The question really relates back to the hose characteristics, and whether a hose that can cope with a little over 100psi at sea level, would be able to cope at 8000 feet.
I was trying to understand what would happen if one was to take a system, charged with 100psi at sea level, up to 8000 feet. Would the pressure in the system be increased by the same proportion as the external air pressure was reduced (ie 25%) - so would the 100psi become in effect 125psi?
Thanks,
Dave
If the system is charged to 100 psi gauge (psig) at sea level and sealed off, then at an altitude of 8000 feet, the pressure would be 103.786 psig, not some percentage more.
Think of it this way, the absolute pressure inside the system at sea level is 114.7 psi absolute (psia), and that stays the same regardless of altitude. Only temperature can change that number, so if your system gets cold it will decrease in pressure, and when heated it will increase in pressure.
So at sea level you have 114.7 psia on the inside and 14.7 psia on the outside, so the net difference is 100 psig which we read as "gauge pressure".
At 8000 feet, you have 114.7 psia on the inside and 10.9 psia on the outside, so the net difference is 103.8 psig. You should be able to measure that with a regular pressure gage.
32K
