Calculating Net Magnetic Field for 3 Parallel Conductors: RHR Method Explained"
The discussion revolves around calculating the net magnetic field produced by three parallel conductors with different current directions. The original poster seeks to determine the net magnetic field at the location of the first conductor based on the configurations and distances between the conductors.
  • Participants discuss the arrangement of the conductors and the directions of the magnetic fields produced by each conductor. Questions arise regarding the correct distances to use in calculations and whether the focus is on magnetic field or magnetic force.
Participants are clarifying the arrangement of the conductors and the corresponding magnetic field directions. Some guidance has been offered regarding the interpretation of distances and the setup of the problem, but no consensus has been reached on the final calculations.
There is some ambiguity regarding the arrangement of the conductors and the distances involved, which may affect the calculations. The original poster's question also reflects a potential misunderstanding of whether to calculate the magnetic field or the magnetic force.
EvaBugs
I have a small question about net magnetic field.
If I have 3 straight conductors that are parallel where
-the current is to the left in conductor #3 (and situated at a distance b from #2)
-the current is to the right in conductor #2. (and is situated at a distance a from #1)
I have to find the net magnetic field exerted by #2 and #3 on the first conductor.
Using RHR I found that:
-conductor #3 , the magnetic field is directed out of the page;
-Conductor #2, the magnetic field is into the page.
To find the net magnetic field, should I use B= KI2/(b+a) - KI2/a
Thank you in advance
Are the conductors arranged in the order of number? #2 between #1 and #3? And was it supposed to say
-the current is to the left in conductor #3 (and situated at a distance b from #1)
and
I have to find the net magnetic force exerted by #2 and #3 on the first conductor
Yes, it's supposed to say that. They are placed on top of the other.
If I am reading it right, the denominator a+b should be b itself. Are you looking for just the magnetic field, or the force on wire #1?
For the net B on wire #1
Then the b+a should be correct
If #1 is on top, then your field directions are reversed. If #1 is on the bottom you have them right
Yes, it is at the bottom
Thank you
  • · Replies 40 ·
