Derivation of Christoffel symbol
by rolandk
Tags: christoffel, derivation, symbol
rolandk
rolandk is offline
#1
May7-05, 08:17 AM
P: 2
Has anyone a derivation at hand of the Christoffel symbol by permuting of indices in a free fall system?
Roland
Phys.Org News Partner Science news on Phys.org
Review: With Galaxy S5, Samsung proves less can be more
Making graphene in your kitchen
Study casts doubt on climate benefit of biofuels from corn residue
pervect
pervect is offline
#2
May7-05, 11:47 AM
Emeritus
Sci Advisor
P: 7,439
If you have the equations for geodesic motion in a coordinate basis, you can "read off" the Christoffel symbols from the equation using the geodesic deviation equation, i.e if [tex]x^a(\tau)[/tex] is a geodesic, and we represent the differentaition with respect to [tex]\tau[/tex] by a dot, we can write
[tex]\ddot{x^a} + \Gamma^a{}_{bc} \dot{x^b}\dot{x^c} = 0[/tex]
MTW gives the example on pg 345 in "Gravitation"
If
[tex]\ddot{\theta} - sin(\theta) cos(\theta) (\dot{\phi})^2 = 0 [/tex]
then
[tex]\Gamma^{\theta}{}_{\phi \phi} = -sin(\theta}) cos(\theta) [/tex]
and the other Christoffel symbols are zero.
I'm not sure if this is what you're looking for, though.
dextercioby
dextercioby is offline
#3
May7-05, 11:55 AM
Sci Advisor
HW Helper
P: 11,863
Section 6.4 of [1] gives exacly what u want.Isn't that
[tex] \Gamma^{\sigma}{}_{\mu\rho}=:e_{\mu}{}^{m}D_{\rho}e_{m}{}^{\sigma} [/tex]
,where the covariant derivative uses the ordinary [itex] \partial_{\rho} [/itex]and the spin-connection...?
Daniel.
[1]Pierre Ramond "Field Theory:A Modern Primer",Addison-Wesley,2-nd ed.,1989
pmb_phy
pmb_phy is offline
#4
May7-05, 12:20 PM
P: 2,955
Quote Quote by rolandk
Roland
Yup. See - http://www.geocities.com/physics_world/ma/chris_sym.htm
This is strictly a mathematical derivation so there is no mention of free-fall. However the condition which is equivalent to it is in Eq. (3).
Please note that one does not "derive" the Christoffel symbols (of the second kind). They are "defined." Once they are defined then one demonstrates relationships between them and other mathematical objects such as the metric tensor coefficients etc. In the link above the Christoffel symbols are defined in the same way Kaplan defines them in his advanced calculus text. In my page that is given in Eq. (8). I know of at least 3 different ways to define them though.
Pete
dextercioby
#5
May7-05, 12:39 PM
Sci Advisor
HW Helper
P: 11,863
Well,Pete,either u or Dirac[1] have it all mixed up.I'd go for you,as Dirac got a Nobel prize and i've been taught GR from his book[1].
Your formula #2 is valid for contravariant vectors ([1],eq.3.3,page 6) (a.k.a.vector,which is defined on the tangent bundle to a flat/curved [itex] \mathbb{M}_{4} [/itex])...So how about getting it all done correctly or,don't give that link anymore and exlude it from your post.
Daniel.
[1]P.A.M.Dirac,"General Relativity",1975.
pmb_phy
pmb_phy is offline
#6
May7-05, 01:23 PM
P: 2,955
Quote Quote by dextercioby
Daniel.
What's with the atttitude dude?? I don't delete portions of my web pages due to the comment of a readed who is a bit ignorant on the subject. As for "giving it" to you, I wasn't. I was giving it to Roland.
As I said, their are several definitions of the Christoffel symbols. Dirac uses one definition, Kaplan another, Ohanian yet another, Lovelock and Rund yet another. However, I'm looking at the text you refer to and I don't see what you're talking about. That equations is not directly related to this topic. Also what you refer to as "valid for contravariant vectors" (really the components of such a vector in a particular coordinate system) is identical in meaning to what I refered to above as the Christoffel symbols of the first kind. The other ones are the Christoffel symbols of the first kind.
So how about first learning the subject completely before you make another attempt at correcting me in such a rude manner?
dextercioby
#7
May7-05, 01:28 PM
Sci Advisor
HW Helper
P: 11,863
Alright,u didn't get it...Let's take it slowly:What's formula #2 about...?
Daniel.
pmb_phy
pmb_phy is offline
#8
May7-05, 01:35 PM
P: 2,955
So why bother with me? Seems that you're unwilling to entertain the possibility that you made an error. In any case Eq. #2 in my page is the transformation properties of the components of a contravariant vector.
However I see your point in Dirac. It was confusing since he never named them. Dirac and Ramond, two authors you quote, use different definitions of the Christoffel symbols of the second kind.
However it appears that you're having a bad day since I find your comments to be irritating.
Later
pmb_phy
pmb_phy is offline
#9
May7-05, 01:37 PM
P: 2,955
However it appears that you're having a bad day since I find your comments to be irritating. A long time ago I found that discussing anything with someone posting in such a grating manner not worth posting to. Li'fe's too short and I have many other irritating things which deserve more attention.
Later
dextercioby
#10
May7-05, 01:38 PM
Sci Advisor
HW Helper
P: 11,863
You specifically use "covariant vector",and 2-ice...And now u turn it and use "contravariant" vector...What should i understand,that I'm having a bad day...?
Daniel.
pmb_phy
pmb_phy is offline
#11
May7-05, 04:07 PM
P: 2,955
Roland
There is a minor point I'd like to make to add to those of mine above. There are four symbols in tensor analysis which are tightly related. In certain circumstances they are identical. In most circumstances you'll see in GR they are identical. Two of the symbols are referred to as the Christoffel symbols (of the first and second kind) and the affine connection symbols (of the first and second kind). The affine connection has a capital gamma as a kernal lettter. There is also two terms referred to as "affine geometry" and "metric geometry.
See
http://www.geocities.com/physics_wor...c_geometry.htm
I'm not 100% sure which symbols are which since I'm not sure everyone uses the same definition of each. In any case they are the same when the manifold has both a connection and metric defined on it and the metric geodesics and the affine geodesics are the same.
Pete
Register to reply
Related Discussions
christoffel symbol+covariant derivative+parallel transport Special & General Relativity 7
Transformation law for Christoffel symbol of first kind Differential Geometry 4
What is the mathematical relationship between Christoffel symbol and Math & Science Software 2
Christoffel symbol as tensor Differential Geometry 20
tutorial on the Christoffel equation used in relativity Special & General Relativity 4
