Div an curl in different coordinate systems
The discussion revolves around calculating the divergence and curl of vector fields in different coordinate systems, specifically cylindrical and spherical coordinates. Participants explore the implications of using the nabla operator in these contexts and question how to apply it without converting to Cartesian coordinates.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the definition of the nabla operator and its application in various coordinate systems. There are attempts to derive expressions for divergence and curl in cylindrical coordinates, with some questioning the correctness of their formulations. Others raise concerns about the implications of using different bases for vector representations.
The discussion is active, with participants providing insights and corrections to each other's reasoning. Some guidance has been offered regarding the use of the nabla operator, but there remains uncertainty about specific calculations and the application of concepts across different coordinate systems.
Participants express confusion regarding the expected outcomes when calculating divergence and curl for unit vectors in cylindrical and spherical coordinates, noting that their results consistently yield zero. This raises questions about the assumptions underlying their calculations and the definitions being used.
Sunshine
To calculate the divergence of a vectorfield in cartesian coordinates, you can think of it as a dot product, and to calculate the curl, you can think of it as a cross product. But how can you calculate the div and curl when you have spherical or cylindrical coordinates, without explicitely converting them to the cartesian system?
For example the radial unity vector e_r = (sin a * cos b, sin a * sin b, cos a)
(standard: a = Theta, b = phi) should affect the curl and div by more than the scaling factor (h)
P.S Is it possible to use tex when writing a post?
I think a good starting point is to define the nabla operator as the operator [itex]\nabla[/itex] such that
[tex]df=\nabla f\cdot d\vec{r}[/tex]
This allows us to recover easily the form of [itex]\nabla[/itex] in any coordinate system.
For exemple, in cylindrical coordinate: Consider a function [itex]f = f(r,\theta,z)[/itex].Then
[tex]df = \frac{\partial f}{\partial r}dr + \frac{\partial f}{\partial \theta}d\theta + \frac{\partial f}{\partial z }dz[/tex]
and
[tex]d\vec{r} = \hat{r}dr + \hat{\theta}rd\theta + \hat{z}dz[/tex]
So after messing around a bit you find that
[tex]df=\nabla f\cdot d\vec{r} \Leftrightarrow \nabla = \hat{r}\frac{\partial}{\partial r} + \frac{\hat{\theta}}{r}\frac{\partial}{\partial \theta}+ \hat{z}\frac{\partial}{\partial z }[/tex]
Hm, shouldn't it be
[tex]d\vec{r} = \hat{r}dr + \mathbf{\dfrac{\hat{\theta}}{r}}d\theta + \hat{z}dz[/tex]
if you divide with the scalefactor?
Otherwise the second equation would become
[tex]df=\nabla f\cdot d\vec{r} \Leftrightarrow \nabla = \hat{r}\frac{\partial}{\partial r} + \hat{\theta}r\frac{\partial}{\partial \theta}+ \hat{z}\frac{\partial}{\partial z }[/tex]
I'm still not sure if I've got it right, but I'll think over this, and return with more questions if they arise. Thanks for the help :)
Sunshine said:
Hm, shouldn't it be
Mmh.. the position vector in cylindrical coordinate is just [itex]\vec{r}=r\hat{r}+z\hat{z}[/itex]. If you differentiate that with respect to an hypothetical variable t, you get
[tex]\frac{d\vec{r}}{dt} = \frac{dr}{dt}\hat{r}+r\frac{d\hat{r}}{dt}+\frac{dz}{dt}\hat{z}+\z\frac{d\hat{z}}{dt} = \frac{dr}{dt}\hat{r}+r\frac{d\hat{r}}{d\theta}\frac{d\theta}{dt}+\frac{dz}{dt}\hat{z}+0 = \frac{dr}{dt}\hat{r}+r\frac{d\theta}{dt}\hat{\theta}+\frac{dz}{dt}\hat{z}[/tex]
And multiplying by dt gives [itex]d\vec{r}[/itex].
Better double check your calculations.
You're right, my mistake
However my biggest problem remains.
Let's look at the position vector
[tex]\vec{r} = (r cos \theta, r sin \theta, z)[/tex]
[tex]\frac{\partial \vec{r}}{\partial r} = (cos \theta, sin \theta, 0)[/tex]
[tex]h_r = \sqrt{cos^2 \theta + sin^2 \theta} = 1[/tex]
and according to the definition
[tex]\hat{r} = \frac{1}{h_r} \frac{\partial \vec{r}}{\partial r} = (cos \theta, sin \theta, 0)[/tex]
the question is, which of the equations below are correct
[tex]\nabla \cdot \hat{r} = \nabla \cdot (1,0,0)[/tex]
OR
[tex]\nabla \cdot \hat{r} = \nabla \cdot (cos \theta, sin \theta, 0)[/tex]
...if I use the [tex]\nabla[/tex] that you gave for cylindrical coordinates.
If it's #1, would #2 apply if the [tex]\nabla[/tex] was defined on another way, i.e not as
[tex]\nabla = \hat{r}\frac{\partial}{\partial r} + \hat{\theta}r\frac{\partial}{\partial \theta}+ \hat{z}\frac{\partial}{\partial z }[/tex]
Both
AND
are correct, if you notice the distinction that in #1, (1,0,0) means [itex](r=1,\theta=0,z=0)[/itex] (i.e. (1,0,0) represents the vector [itex]\hat{r} = 1\hat{r}+0\hat{\theta}+0\hat{z}[/itex]), while in #2, [itex](cos\theta,sin\theta,0)[/itex] means [itex](x=cos\theta,y=sin\theta,z=0)[/itex] (i.e. represents the vector [itex]\hat{r}=cos\theta \hat{x} + sin\theta \hat{y} + 0\hat{z}[/itex]
The base of [itex]\mathbb{R}^3[/itex] used in #1 is different than that used in #2. Therfor if you're going to take the dot product of either of them with nabla, you got to express nabla in the same base.
so you mean that
[tex](\frac{\partial}{\partial x}, \frac{\partial}{\partial y},\frac{\partial}{\partial z }) \cdot (cos \theta, sin \theta, 0) = (\frac{\partial}{\partial r}, \frac{1}{r}\frac{\partial}{\partial \theta},\frac{\partial}{\partial z }) \cdot (1,0,0)[/tex]
Well, I see that it's true in this case where both sides are zero but is it so for an arbitrary vector field?
And is curl similar?
Of course.Remember that the divergence of a vector field is a scalar wrt general coordinates transformations,so eveluating it in cartesian is no difference than eveluating it in cylindrical or spherical...:wink:
As for the curl,well,it gives a pseudotensor of a higher rank,so it's not invariant under general coordinate transformations...
Daniel.
I've turned those formulas upside down by now, and still very confused... :confused:
The thing is that I'm supposed to calculate [tex]\nabla \cdot \vec{e_x}[/tex] and [tex]\nabla \times \vec{e_x}[/tex] where [tex]\vec{e_x}[/tex] are the unit vectors with [tex]x = r, \rho, \theta, \phi[/tex] (cylindrical and spherical coordinates).
It means a total of 8 "questions" and all of them (!) becomes 0 if I use any of the equations in my last post (you always get 0 when differentiating a scalar)... that's why I've been suspecting that I'm supposed to use
[tex]\vec{e_r} = (cos \theta, sin \theta, 0)[/tex]
[tex]\vec{e_{\theta}} = (-sin \theta, cos \theta, 0)[/tex]
etc. and differentiate with respect to [tex]r, \theta, \phi ...[/tex]
But that isn't the case...?
