Global Temperature Rising: Troposphere & Water Vapor
  • Thread starter Thread starter Soaring Crane
    Temperature
The discussion revolves around the relationship between rising global temperatures, the troposphere, and water vapor. Participants explore theoretical implications, potential feedback mechanisms, and the effects on climate zones, with a focus on atmospheric dynamics and historical climate patterns.
  • Some participants question whether rising global temperatures will lead to increased water vapor in the troposphere.
  • One participant argues that enhanced greenhouse forcing may lead to stronger heating in the lower atmosphere, potentially resulting in cooling in the upper atmosphere, which could affect water vapor levels and cloud formation.
  • There is a suggestion that increased cloud cover could create a negative feedback loop by reflecting solar radiation, thus limiting warming despite higher water vapor levels.
  • Another participant raises the possibility that climate belts could shift northward with rising temperatures, questioning whether this would lead to cooler conditions in tropical areas.
  • One viewpoint posits that changes in Hadley cell circulation due to differential heating could have complex and unpredictable impacts on global climate, rather than a straightforward shift in climate zones.
Participants express differing views on the implications of rising temperatures for water vapor and climate dynamics. There is no consensus on the effects of increased water vapor or the outcomes of shifting climate belts.
Participants reference historical climate periods and feedback mechanisms without resolving the complexities of these interactions. The discussion includes assumptions about the behavior of atmospheric systems under changing conditions.
Soaring Crane
If global temperature(s) continues to rise, does that mean that the troposphere will contain more water vapor?
The big debate about water vapor is this versus http://www.climate2003.com/blog/arking.htm
You can also see it in this quick and dirty way:
If the Earth heats up more due to the enhanced greenhouse forcing then this heating will be strongest in the lower atmosphere, where most greenhouse gas is and it's closest to the source, the infrared radiating heat.
Too bad for the global warmers that this heat is not showing in the radio sondes temperature registration that measure exactly that area of the atmosphere, but anyway.
So if more infra red radiation is captured directly in the lower atrmosphere, the higher part of the atmosphere receives less IR radiation that the greenhouse gasses can capture and heat the air with. The cooling is actually occurring but no-one knows exactly why. Cooler upper air means less water vapor in the air and more condensation - hence clouds. Furthermore a higher vertical temperature gradient in the atmosphere means unstable conditions, convection and even more clouds forming. More clouds is probably having a negative feedback effect, more incoming solar radiation is reflected and there is less solar energy to capture with the greenhouse gas effect. So water vapor may have a negative feedback although it is the strongest greenhouse gas.
Are there examples of that negative feedback?
Perhaps. Try the paleao glacial confusion thread. We see two very wet era's (the Bolling Allerod and the Preboreal) with simulatenous massive glacier growing. Hence not that much warming despite the very moist conditions.
Oh, another question. From global warming, climate belts could shift northward by about 100 km in altitude for each increase in degree of temp. Does this mean tropical areas will become cooler than they are now?
Anyone?
Thanks.
Interesting question. The heating of the Earth causes Hadley cells and those govern the climate zones.
http://www.newmediastudio.org/DataDiscovery/Hurr_ED_Center/Easterly_Waves/Trade_Winds/Trade_Winds.html
In the hypothetical case that increased greenhouse gas concentrations would greatly increase the warming due to absorption of reradiated IR energy, it could be argued that the downdraft areas, the arid climates would heat more than the updraft areas (the moist climates). That unbalance could destroy the circulation of the hadley cells and have very unpredictable impact on the global climate. It would be more complicated than a simple shift of climate belts.
  • · Replies 79 ·
10K
  • · Replies 28 ·
  • · Replies 64 ·
