Solve Speed Problem: Plate Reaches 40m Height & 70m Length
  • Thread starter Thread starter Kahsi
    Mechanics Speed
The discussion revolves around a physics problem involving the motion of a plate thrown into the air, reaching a height of 40 meters and traveling a horizontal distance of 70 meters. Participants are exploring the calculations related to the speed of the plate and the relationships between various kinematic equations.
  • The original poster attempts to calculate the vertical and horizontal speeds of the plate using energy conservation and kinematic equations. Some participants question the accuracy of the time calculation and the interpretation of height versus distance in the context of free fall.
Participants are actively engaging with the problem, providing feedback on calculations and clarifying concepts related to height and distance. There is an ongoing exploration of the relationships between different variables, but no consensus has been reached on the correct speed of the plate.
There is a mention of potential confusion regarding the definitions of height (h) and distance (s) in the context of the problem, as well as the implications of positive and negative signs in kinematic equations.
Kahsi
Hi.
A man is throwing a plate in the air. The plate reaches the height of 40m and the length of 70m. What was the speed of the plate?
This is what I've done
[tex]v_y:[/tex]
[tex]mgh = \frac{mv^2}{2} => v = \sqrt{2gh} = \sqrt{2*9,82*40} = 28m/s[/tex]
[tex]v_x:[/tex]
[tex]v = v_0 + at => t = 28/9,82 = 2,85s[/tex]
[tex]s = vt => v = s/t = 70/2,85 = 24,56m/s[/tex]
Code:
                   /    | v_y = 28m/s
           v_z   /      |
         /______________|
         v_x = 24,6m/s
[tex]v_z = \sqrt{v_y^2+v_x^2} = \sqrt{24,6^2 + 28^2} = 37m/s[/tex]
But the answer should be 31m/s. What am I doing wrong?
Thank you.
Initial v_y is 28 m/s, but final is -28m/s, so total change is 56m/s and you've calculated t incorrectly; it is actually twice the value you gave.
Thank you for the reply krab.
I have now another question.
We know that
[tex]mgh = \frac{mv^2}{2} => h = \frac{v^2}{2g}[/tex]
And we also know that [tex]s = v_0t + \frac{at^2}{2}[/tex]
When it's a free fall [tex]v_0 = 0[/tex]. That gives us
[tex]s = -\frac{gt^2}{2}[/tex]
So what's the difference between s and h?
Thank you.
Your expression for h is in terms of the speed v when the object hits the ground.
The object's speed at time t is
v = gt
so t=v/g
Putting this into your expression for s, we get:
[tex]s = -\frac{gt^2}{2} = -\frac{g}{2}\frac{v^2}{g^2} = -\frac{v^2}{2g} = -h[/tex]
So, as you can see, h and s are the same, apart from the negative sign. The negative sign comes from the fact that in one case you've measured positive distances downwards, and in the other positive distances are upwards.
  • · Replies 53 ·
  • · Replies 25 ·
