How to Model a Two-Mass Pendulum System Using ODEs?
  • Context: Graduate
  • Thread starter Thread starter mathgirl
    Odes Pendulum System
This discussion focuses on modeling a two-mass pendulum system using ordinary differential equations (ODEs). The system consists of two masses, m1 and m2, positioned at distances k and L from a fulcrum, respectively. The equations of motion are derived using Newton's second law, resulting in the relationships m1x1'' = T1sinθ - m1gcosθ and m2x2'' = T2sinθ - m2gcosθ. The small angle approximations for sinθ and cosθ are applied to simplify the equations for further analysis.
  • Understanding of Newton's second law of motion
  • Familiarity with ordinary differential equations (ODEs)
  • Knowledge of trigonometric approximations (small angle approximation)
  • Basic principles of oscillatory motion
  • Explore numerical methods for solving ODEs, such as the Runge-Kutta method
  • Learn about the stability analysis of nonlinear systems
  • Investigate the effects of damping on oscillatory systems
  • Study the application of Lagrangian mechanics to complex systems
Physics students, mechanical engineers, and anyone interested in modeling dynamic systems using differential equations.
mathgirl
Can anyone help me figure out how to model this pendulum system using ODE's? It is a two-mass system in which the two masses are placed at opposite ends of a massless rod, with a fulcrum somewhere in the middle. The smaller mass is length k away from the fulcrum and the larger mass is length L away from the fulcrum.
Could u attach a drawing,please and explain what sort of oscillations are u looking for...?
The physics involved would be only a wise application of Newton's second law for nonlinear movement (extended bodies).
Daniel.
Sure, I can try to help you with modeling this pendulum system using ODEs. First, let's define some variables:
- Let m1 be the mass of the smaller mass and m2 be the mass of the larger mass.
- Let k be the distance of the smaller mass from the fulcrum and L be the distance of the larger mass from the fulcrum.
- Let x1 and x2 be the horizontal positions of the smaller and larger masses respectively, with x1 = -k and x2 = L.
- Let θ be the angle made by the rod with the vertical direction.
Now, we can use Newton's second law to write down the equations of motion for the two masses:
where T1 and T2 are the tensions in the rod acting on the smaller and larger masses respectively.
Next, we need to relate the horizontal positions x1 and x2 to the angle θ. Since the rod is massless, the distance between the two masses remains constant, and we can use the Pythagorean theorem to write:
(x2 - x1)^2 + (L - k)^2 = (L + k)^2
Expanding and simplifying, we get:
x2^2 - 2x1x2 + x1^2 + L^2 - 2Lk + k^2 = L^2 + 2Lk + k^2
Simplifying further, we get:
x2^2 - 2x1x2 + x1^2 = 4Lk
Now, we can use the small angle approximation sinθ ≈ θ and cosθ ≈ 1 to rewrite the equations of motion as:
m1x1'' = T1θ - m1g
m2x2'' = T2θ - m2g
We also need to express the tensions T1 and T2 in terms of θ. From the diagram, we can see that:
T1sinθ = m1x1'' + m1gcosθ
T2sinθ = m2x2'' + m2gcosθ
Substituting these into the equations of motion, we get:
  • · Replies 31 ·
  • · Replies 19 ·
  • · Replies 76 ·
