Matrix element (raising and lowering operators)
The discussion revolves around determining the matrix representation of position and momentum operators using energy eigenstates as a basis, particularly in the context of the simple harmonic oscillator (SHO). The participants explore methods for transforming these representations and the implications of degeneracy in eigenstates.
  • One participant suggests that knowledge of the Hamiltonian as a function of position and momentum operators is essential for solving for the eigenstates in the position or momentum representation.
  • Another participant outlines a method for linking energy eigenstates to solutions of the Schrödinger equation, noting that this mapping can vary in complexity depending on degeneracy.
  • A participant introduces the concept of a unitary transformation from the Hamiltonian matrix elements to those of the position and momentum operators, emphasizing the need for consistency in the basis used.
  • There is a mention of potentially more elegant algebraic methods for the SHO, particularly involving creation and annihilation operators, though the generality of this approach is questioned.
  • Participants express curiosity about the implications of the discussion, particularly regarding the specific context of the simple harmonic oscillator.
Participants generally agree on the relevance of the simple harmonic oscillator to the discussion, but there are differing views on the methods and implications of transforming the matrix representations of operators.
The discussion does not resolve the complexity of the mapping between energy eigenstates and the solutions of the Schrödinger equation, nor does it clarify the general applicability of the algebraic methods mentioned.
ayalam
How to determine the matrix representation of position & momentum operator using the energy eigenstates as a basis
You need to know your hamiltonian as a function of the position and momentum operators. Once you know that, you can solve for the eigenstates of the hamiltonian in the position or the momentum representation (by solving the associated Schroedinger equation). Then you need to find a link between your specific given basis of energy eigenstates you mentionned, and the solutions of the Schroedinger equation you found in the (say) position representation. This mapping can be trivial (in the non-degenerate case) because for same eigenvalues, you have a clear identification between your solution of the Schroedinger equation with that eigenvalue and the given energy eigenstate (well, up to a phase factor...). It can also be more complicated in the degenerate case. Then you'll need to look at how exactly the energy eigenstates of your given basis are defined.
In any case, you end up by finding an equivalence:
f_E (x) <--> |E> ; so you can consider that f_E(x) = <x|E>
This means that f_E(x), now seen as F(E,x) is the matrix element of the basis transformation that maps the basis {|x>} into the basis {|E>}. That's sufficient to transform your representation of the position operator X (which is simply x delta(x-x0) for <x|X|x0>) into the |E> basis <E |X|E> ; and in the same way to transform the representation of P in the |x> basis into a representation in the |E> basis.
What I've outlined above is the pedestrian method. Sometimes more elegant algebraic methods exist: for instance in the case of the harmonic oscillator, with the creation and annihilation operators. I don't know how general that approach is.
cheers,
Patrick.
Funny,the title mentioned raising & lowering ladder operators.Could he possibly mean the SHO?:rolleyes:
Daniel.
yes i did mean sho.
Voilà.So you're interested in making a unitary transformation from the matrix
[tex]\langle i|\hat{H}|j\rangle[/tex] (i,j can run from 0 to +infinity)
to [tex]\langle i|\hat{x}|j\rangle [/itex] and [tex]\langle i|\hat{p}|j\rangle [/itex] ,where,now <br /> <br /> [tex]|i\rangle \longrightarrow \langle x|i\rangle [/itex]<br /> <br /> ,i.e.u'll be needing the SHO-s wavefunctions.U can use only coordinate ones,just as long as u express the momentum operator in the same basis [itex]\{\langle x| \}[/itex].<br /> <br /> <br /> Daniel.[/tex][/tex][/tex]
