What Are Common Mistakes in Calculating Electron Transitions and Spectral Lines?
  • Thread starter Thread starter scorpa
    Electron
This discussion focuses on common mistakes in calculating electron transitions and spectral lines in hydrogen-like atoms. The first question involves calculating the momentum of an electron in the third energy level, where the user incorrectly applies the energy formula for the second level. The second question pertains to identifying the electron transition responsible for a spectral line, where the user misapplies Rydberg's equation. Correct answers for the momentum and transition are 1.34 x 10^-24 kg*m/s and a transition from level 5 to level 2, respectively.
  • Understanding of quantum mechanics principles, specifically electron energy levels
  • Familiarity with Rydberg's equation for spectral lines
  • Knowledge of momentum calculations in physics
  • Basic understanding of diffraction and its relation to wave properties
  • Review the derivation and application of Rydberg's equation for hydrogen transitions
  • Study momentum calculations in quantum mechanics, particularly for electrons in atomic orbits
  • Explore the concept of energy levels in hydrogen-like atoms and their implications for electron transitions
  • Investigate diffraction grating principles and their role in analyzing spectral lines
Students and educators in physics, particularly those focusing on quantum mechanics, atomic structure, and spectroscopy. This discussion is beneficial for anyone looking to deepen their understanding of electron transitions and spectral analysis in hydrogen-like atoms.
scorpa
Hello Everyone,
I've been doing some physics homework and have gotten all but two of the questions. They are on electron transitions.
#1) In a hypothetical hyrogen like atom the energy of the second energy level is -13.6eV. Calculate the momentum of the electron in the third energy level of this atom.
En = (1/3^2)(13.6) = 1.51 ev
1.51 eV = 2.42 x 10^-19 J
Ek = (1/2)mv^2
square root of (2.42x10^-19J/(0.5 x 9.11 x 10^-31) )
v = 7.3 x 10^5 m/s
p = mv
p = (9.11x10^-31kg)(7.3x10^5m/s) = 6.7 x 10^-25 kg*m/s
The answer should be 1.34 x 10^-24 kg*m/s
I have no idea what I've done wrong
#2) A spectra line in the hydrogen bright line spectra (NOTE: visible region) passes perpendicularily through a diffraction grating (d= 5.00x10^-6m). This spectra line produces a first order maximum at an angle of 4.97 degrees. What is the transition of the elctron that produces this spectra line?
wavelength = (5.00 x 10^-6m)(sin4.97)/1 = 4.33 x 10^-7m
Using Rydberg's equation I subsituted and manipulated and got:
(1/4) - ((1/4.33x10^-7)/1.1x 10^7) then I took the square root of that and got 0.2 which definitely isn't right.
The answer should be 5 to 2. Once again I don't know where I've gone wrong.
Any help is greatly appreciated, thanks in advance!
Ek = (1/2)mv^2
v = 7.3 x 10^5 m/s
p = mv
I will look at these one at a time.
Two things you need to look at. 1) Your equation for En is not giving you the correct result for the initial energy level that was stated to be the SECOND energy level, not the first. 2) What are you doing about the potential energy in your calculations?
I think your wavelength is OK, but I don't follow your application of the Rydberg. Take a look here and find a common denominator for the difference of 1/n^2 and combine fractions so that you can solve for the reciprocal of the fraction. You will have n1^2n2^2 in the denominator. You have the information to find the value of this fraction. Figure out which combination of small integer values of n give you the right ratio.
http://hyperphysics.phy-astr.gsu.edu/hbase/hyde.html
9K
