Main Sequence Stars: Mass & Beyond
  • Context: Undergrad
  • Thread starter Thread starter Baggio
    Mass Sequence Stars
The discussion revolves around the characteristics of main sequence stars, particularly why most stars are found on the main sequence and the factors influencing their classification. Participants explore the relationship between mass, luminosity, and other properties of stars, as well as the implications of metallicity and nuclear burning processes.
  • Some participants suggest that the main sequence is characterized primarily by hydrogen burning, with most stars lying on it due to their mass, starting from brown dwarfs upwards.
  • It is noted that stars do not progress down the main sequence in a linear fashion but rather 'jump' off when they exhaust their hydrogen fuel, with their subsequent evolution depending on mass and composition.
  • One participant raises questions about the relationship between surface luminosity and mass, suggesting that while hydrogen burning occurs in the core, the observed properties are linked to the photosphere.
  • Another participant mentions that the physical conditions on a star's surface are influenced more by pressure and gravity than by nuclear burning, which primarily affects the star's lifetime.
  • The impact of metallicity on stars is discussed, with some noting that the presence of metals alters radiative opacity and luminosity, affecting the star's color and brightness.
  • Questions are posed regarding the differences between stars burning in their cores versus those undergoing shell burning, particularly in the context of red giants.
  • One participant references a seminar discussing heavy metal diffusion and its correlation with luminosity, suggesting further exploration of these concepts.
Participants express a range of views on the factors influencing main sequence stars, with no consensus reached on the specifics of how mass, metallicity, and burning processes interact. The discussion remains open-ended with multiple competing ideas presented.
Some assumptions about the relationship between nuclear burning and stellar structure are not fully explored, and the discussion includes varying definitions of metallicity that may affect interpretations of the arguments presented.
Baggio
Straight forward questions that's been bugging me a little. Why do most stars lie on the main sequence whilst others don't? Is it just purely characterised by the mass?
Thanks
Astronomy news on Phys.org
The main sequence is basically the location on the Hertzsprung-Russel diagram where hydrogen-burning stars sit. Every star more massive than a brown dwarf (~0.1 solar masses) will be on it at some point in its life. In fact, stars spend the majority of their lives on the main sequence, so it shouldn't be surprising that most of what we see is on it. They leave the main sequence when they run out of hydrogen to burn in the core. Examples of non-main sequence stars are white dwarfs, asymptotic giant branch stars, and protostars.
Space tiger summed it up pretty well. A Main sequence star is simply one that is predominantly burning hydrogen as its source of energy. One thing to note is that stars do not really progress down the Main sequence from Upper left to lower right on an HR diagram. They do move along it, but at a certain point they basically 'jump' off, when the hydrogen runs out. Where they go depends on their mass and composition.
That's right, the motion along the main sequence during their lifetime is very small. To zeroth order, a given star will only sit at one position on the main sequence for most of its life. Moving up the main sequence is basically equivalent to moving to higher-mass stars.
Just to make your life a little more exciting Baggio (and extend the excellent answers from ST, so keeping this thread alive a bit longer) ... why do H-burning stars end up with this particular relationship between (surface) luminosity and mass (or surface temperature or ...)? I mean, the 'H-burning' occurs deep, deep down, in the core, yet what we see is the photosphere - even if 'H-burning' cores are all the same (varying only by mass?), why should the photospheres all end up the same too?
You also know that there is a considerable range of 'metalicity' in main sequence stars (astronomers are funny folk, they say 'metal' for any element heavier than He ... so to them even O and N and C are 'metals'!) - does that make a difference?
It may be intuitively OK that protostars and white dwarfs are different, but why should 'shell-burning' make red giants (etc) so much different from their twins, stars of the same mass but burning in the core (not a shell)?
math wise-prolly stability and fundamental burning that was stated above.
Actually, believe it or not, the physical conditions on the surface of the star are not determined by nuclear burning. In fact, we had a fairly good idea of the structure of the sun before we even knew about nuclear burning. The majority of a star's structure is determined by battle between pressure and gravity. The thing determined by fusion is how long it can maintain this equilibrium. The star is cooling via the light it emits, so the fusion is needed to keep the temperature up and maintain the pressure. In other words, the energy source determines the lifetime, not the structure or appearance.
Metals have two effects. First, their absence or presence will alter the radiative opacity of the atmosphere. This will, in turn, alter the luminosity. Specifically, metals tend to make the atmospheres more opaque, decreasing the luminosity. Thus, metal-poor stars (subdwarfs) are dimmer. The other effect of metals is to alter the spectrum and, therefore, the color. Metals contribute a lot of absorption lines/bands/edges, so a star of equivalent luminosity and temperature will have a different color if it has fewer metals.
The envelopes of stars expand into giants expand because their cores contract (conservation of energy). Their cores contract because they can no longer support themselves with nuclear reactions, so they collapse until degeneracy pressure kicks in. If the star is massive enough, it will eventually start burning helium and the core will expand again, allowing the star to shrink back to a more reasonable size.
I came across(I was looking into luminosity function), an interesting lecture/seminar by Anthony Aguirre entitled Enigmas In Galaxy Formation:http://streamer.perimeterinstitute....aspx?cid=a9b1d20a-efa7-485f-8d5d-3b62fb7d3e4c
the seminar is on page 7 of 11, and you will need WMP 9 or later,
half way through he gives a specific overview on the reasons for the existence of how:Metals exist outside of Galaxies, and the process of Heavy metal diffusion implimented by the Galactic Wind(which Iam delving into its correlation with Luminosity), you may find some interesting recent thoughts on Star formation, Dark Matter, and 'Surface Critical Density' which may have a baring on your post?
  • · Replies 42 ·
  • · Replies 28 ·
  • · Replies 48 ·
  • · Replies 72 ·
  • · Replies 26 ·
