More precise numbers on 2004MN4 asteroid flyby in 2029
  • Context: High School
  • Thread starter Thread starter marcus
    Asteroid Numbers
The 2004 MN4 asteroid is projected to pass Earth at an altitude of approximately 30,000 km on April 13, 2029, making it visible from parts of Europe, Asia, and Africa, even in urban areas. The asteroid measures about 320 meters in width and will shine like a third-magnitude star during its flyby. Recent data from JPL Horizons indicates that the trajectory predictions have stabilized, with a consistent 1 in 40,000 chance of impact despite the close approach. The latest trajectory analysis, dated May 6, 2005, shows minimal changes from previous predictions, reinforcing confidence in the current estimates.
  • Understanding of asteroid classification and characteristics
  • Familiarity with JPL Horizons data and trajectory analysis
  • Knowledge of astronomical magnitude scales
  • Basic principles of orbital mechanics
  • Research asteroid impact probabilities and risk assessment methodologies
  • Explore JPL Horizons for real-time trajectory updates on near-Earth objects
  • Learn about radar techniques used in asteroid tracking and measurement
  • Investigate the effects of light pollution on astronomical observations
Astronomers, astrophysicists, space enthusiasts, and anyone interested in planetary defense and asteroid monitoring.
marcus
Dearly Missed
http://science.nasa.gov/headlines/y2005/13may_2004mn4.htm?list45222
apparently they've crunched more numbers and can say that the asteroid will pass Earth at altitude of some 30,000 km
shining like a 3rd magnitude star
If I understand correctly, we are being told that it will pass Earth at a distance roughly like that of a geosynchronous communication satellite.
it is about 320 meters wide, so if you are in the part of europe, asia, africa where it is visible you might see it when it passes. the article says visible even where there are city lights
I don't know how much of this new, or how reliable it is. It is a lot more definite than back in 2004 when they were thinking it might run into the Earth and estimates seemed to change daily
Astronomy news on Phys.org
I thought they had since backed off that 30k distance, but it's true the estimates have frequently and presumably will continue to change over the next 20+ years. It is very difficult to predict long term orbits of these little rogues. I will be quite nervous if they are still saying 30k in 2028... assuming I'm still lucid.
Here's an illustration of the latest trajectory.
http://orbitsimulator.com/orbiter/2004mn4may.GIF
I threw this together with data from JPL Horizons. It looks like it did get notched slightly closer in recent weeks. According to JPL, the latest data is a solution generated on May 6, 2005. The double purple line in the image is February's prediction and the May 6 prediction. Approaching Earth, they are virtually identical. After Earth passage, they split apart slightly.
I don't think they're going to change that much between now and 2029. Just a little more of the same of what you see in the image between the Feb prediction and the May prediction. I think they're comfortable that the error bar does not include Earth even though the asteroid's close approach point is only about 30,000 km. When the predicted pass was at abou6 60,000, they were giving it a 1/32 chance of striking. Then, without changing the 60,000 estimate by much they lowered it to something like 1 in 40,000. Then a month later, they moved the close passage point twice as close, to about 30,000, but still maintained the 1 in 40,000 chance of a strike.
I just took this to mean that in December it was 1 in 32 with a really large error bar, then they shrank the error bar enough to exclude Earth, but not the 30,000 km point. Then, in January, they shifted the predicted passage to about 30,000 which was still in the fat part of the error bar of the 60,000 km point. In January, they actually bounced radar off it. That's when they shoved it a little closer, and shrank the error bar as well.
