Niels Bohr atom and magnetic fiels
The discussion revolves around the application of the Biot-Savart Law to calculate the magnetic field produced by an electron orbiting a proton in the context of the Niels Bohr model of the hydrogen atom. Participants explore the relationship between the electron's motion and the resulting magnetic field at the position of the proton.
  • The original poster attempts to relate the electron's circular motion to a current and uses the Biot-Savart Law to derive the magnetic field. Some participants question the appropriateness of using a conductor model for a single electron and suggest considering the frequency of the electron's passage at a point in its orbit to determine current.
Participants have engaged in a productive exchange, with the original poster refining their understanding of current in the context of the problem. There is acknowledgment of the algebraic approach taken by the original poster, and further exploration of the implications of the magnetic field calculation is suggested.
Participants note the distinction between the behavior of a single electron in the Bohr model and that of electrons in a conductor, raising questions about the assumptions made in the original approach.
tiagobt
Niels Bohr atom and magnetic fields
Could anyone help me solve the following problem?
According to 1913 Niels Bohr hydrogen atom model, an electron orbits a proton from a distance of [itex]5.29 \times 10^{-11} m[/itex] with a velocity of [itex]2.19 \times 10^6 m/s[/itex]. Find the intensity of the magnetic field produced by this movement in the position of the proton.
I am supposed to use Biot-Savart Law. What I tried was:
The orbit of the electron can be interpreted as a current flowing in a circular spire (on the opposite direction of the electron's velocity). If an element [itex]d \vec{s}[/itex] of the spire produces a field [itex]d \vec{B}[/itex] in the position of the proton, the intensity of [itex]d \vec{B}[/itex] can be written as the following:
[itex]dB = \frac{\mu_0ids}{4 \pi R^2}[/itex]
[itex]B = \frac{\mu_0i}{4 \pi R^2} \oint ds[/itex]
Calculating the integral for the entire circle:
[itex]B = \frac{\mu_0i2 \pi R}{4 \pi R^2} = \frac{\mu_0i}{2R}[/itex]
And then I tried to calculate the electical current as a function of the electron's velocity of displacement:
[itex]i = nq_{e}v_{d}A[/itex]
Where [itex]n[/itex] is the number of free charged particles, [itex]q_e[/itex] is the charge of an electron, [itex]v_d[/itex] is the velocity of displacement of the charge and [itex]A[/itex] is the area of section of the current conductor. I am not sure what [itex]A[/itex] could be in the original problem. Am I making any sense?
Thanks,
Tiago
That's the formula for the current in a conductor of cross-section A, in terms of the motion of the electrons in it. In the Bohr atom, you don't have a conductor, you don't have a cross-section, and you don't have a number density of electrons (n).
What you do have is a single electron traveling in a circular path. Suppose you're standing next to a point on that circular path (and that you're very tiny :smile: ). How many times per second does that electron pass you? How many coulombs per second does that work out to, counting each "pass" as a separate chunk of charge?
Thanks so much! I think I got it now. Just to make sure my ideas are correct:
In each period [itex]T[/itex], the electron passes through the point "where I am standing" once. That means that there is a charge of [itex]q_e[/itex] every [itex]T[/itex] seconds:
[itex]i = \frac{q_e}{T} = \frac{q_e}{\frac{2 \pi R}{v}} = \frac{q_e v}{2 \pi R}[/itex]
Sustituting [itex]i[/itex] in Biot-Savart Law:
[itex]B = \frac{\mu_0}{2R} \frac{q_e v}{2 \pi R} = \frac{\mu_0 q_e v}{4 \pi R^2} = k_m \frac{q_e v}{R^2}[/itex]
I think that's it!
Thanks again
Yep, that's it. You even did it algebraically, without plugging in any numbers until the end! :!) My students always calculate every intermediate number along the way unless I whack them by taking points off for it.
Having done a classical calculation of the field at the proton, it is just one step further to calculate the interaction energy of the proton spin with this field. That, at least might tell you something. I don't see what physical idea comes out of calculating the field alone...perhaps it's just to give you practice with calculations like this?
  • · Replies 17 ·
  • · Replies 16 ·
