How Does a Carnot Refrigerator Work Between Different Temperatures?
The discussion revolves around a problem involving a Carnot refrigerator operating between two heat reservoirs at different temperatures (320K and 270K). Participants are tasked with determining the heat delivered to the higher temperature reservoir and the power input required for the refrigerator's operation.
  • Participants explore the efficiency expression for a Carnot refrigerator and question how to relate work done to heat absorbed and rejected. There are inquiries about the conservation of quantities in the ideal Carnot cycle and the implications of entropy changes.
The discussion is ongoing, with participants seeking clarification and guidance on the relationships between heat quantities and work in the context of the Carnot cycle. Some have provided hints regarding the coefficient of performance and the need to show work, indicating a productive direction without reaching a consensus.
Participants note the importance of showing work and understanding the underlying principles of the Carnot cycle, suggesting that assumptions about reversibility and conservation are under consideration.
ziddy83
hey everyone,
I need some help solving the following problem. I am kind of confused on where to start. here is the question from the book.
A carnot refrigerator is operated between two heat reservoirs at temperatures of 320K and 270K.
a) If in each cycle the refrigerator receives 415J of heat energy from the reservoir at 270k, how many joules of heat energy does it deliver to the reservoir at 320k?
b)If the fridge goes through 165 cycles each minute, what power input is required to operate the refrigerator?
Thanks in advance for any help.
Anyone...?
What is the efficiency expression for a carnot refrigerator in terms of source and sink temperatures; heat absorbed from source and heat rejected to sink. Equate them and simplify.
How can you know work done from the heat abosrbed and heat rejected? After that it is simple algebra.
ziddy83 said:
Anyone...?
You need to show some work. Think about the two quantities that are conserved in the ideal carnot cycle (hint: it's a reversible process).
ziddy83 said:
hey everyone,
Over one cycle: [tex]Q_H/T_H + Q_C/T_C = \Delta S[/tex]
What is [itex]\Delta S[/tex] over one cycle? What does that tell you about Q_H?<br /> <br /> The co-efficient of performance for a refrigerator is:<br /> <br /> [tex]COP = \frac{Q_C}{W} = \frac{Q_C}{Q_H - Q_C}[/tex]<br /> <br /> Can you work W out in terms of temperatures and COP? Find W from that (one cycle) and then work out work consumption in 165 cycles. That is the energy / minute or power.<br /> <br /> AM[/itex]
9K
  • · Replies 20 ·
