Solved: Forces on a Bike: Calculating Friction and Total Force
  • Thread starter Thread starter Rockdog
    Bike Forces
The discussion focuses on calculating forces acting on a bike during a turn, specifically addressing friction and total force. The student rides at a speed of 8.1 m/s around a 30-meter radius corner with a combined mass of 89 kg. The force of friction is calculated to be 194.643 Newtons, while the minimum coefficient of static friction required to prevent skidding is determined to be 0.223. The total force between the bike tire and the road, which equals the centripetal force, is also confirmed to be 194.43 Newtons.
  • Understanding of Newton's second law of motion
  • Knowledge of centripetal force calculations
  • Familiarity with static friction and its coefficient
  • Basic algebra for solving equations
  • Study the derivation of centripetal force equations
  • Learn about static friction and its applications in real-world scenarios
  • Explore the concept of net force and its implications in circular motion
  • Investigate the effects of different coefficients of friction on vehicle dynamics
This discussion is beneficial for physics students, mechanical engineers, and anyone interested in understanding the dynamics of motion and forces acting on vehicles during turns.
Rockdog
A biology student rides her bike around a corner of radius 30 meter at a steady speed of 8.1 m/sec. The combined mass of the student and the bike is 89 kg. The coefficient of static friction between the bike and the road is ìs = 0.32.
a) If she is not skidding, what is the magnitude of the force of friction on her bike from the road?
b) What is the minimum value the coefficient of static friction can have before the bike tire will skid?
c) What is the magnitude of the total force between the bike tire and the road?
I'm stuck on part c, but maybe doing part a and b can help out also.
a) A=v^2/R
so A=8.1^2/30=2.187m/s/s
Then I used F=m*a => 89kg*2.187m/sec/sec => 194.643 Newtons
b) Well, I used Newton's second law for the x axis, and figured out that
-fs= -m(v^2/R)
where fs is static friction force, m is mass, v is velocity, R is radius
and I know that fs(max)=Us*N
where Us=static coefficient of friction
N=normal
so I plug in for fs and solve for Us.
Us=(m*v^2)/(N*R)
since N=m*g
Us=(m*v^2)/(m*g*R) or Us= (v^2)/(g*R)
plug in my numbers, and I get minimum Us to be .223. That is when the bike is on the verge of skidding.
c) Here is where I get stuck. I want the total force between bike tire and the road. I did a force diagram of the bike, with a mg force pointing down, a Normal force pointing up, and a frictional force to the left.
So I tried adding weight of the bike/girl to the frictional force, but that doesn't work. I'm pretty sure I need to add the normal force of the girl into there, but to what other force, if any, I'm stuck on.
You are correct so far.
Consider the forces from the ground on the bike:
THe normal force, pointing up, and the static friction, pointing to the left. THat's it. Find the resultant of these two perpendicular components.
Great job on parts a and b! To solve part c, we need to consider the forces acting on the bike in the horizontal direction. These forces include the force of friction, the force of normal reaction (from the ground), and the force of inertia (centripetal force).
First, let's find the centripetal force using the formula Fc = mv^2/R. Plugging in the values, we get Fc = 89kg * (8.1m/s)^2 / 30m = 194.43 Newtons.
Next, we can use Newton's second law to find the total force in the horizontal direction. This is given by the formula F = ma, where a is the acceleration in the horizontal direction. We can calculate the acceleration using the centripetal force and the mass of the bike and rider. So, F = (89kg * 2.187m/s^2) = 194.643 Newtons.
Now, we can set up an equation for the forces in the horizontal direction:
F - fs = ma
Where fs is the force of friction, and a is the acceleration we just calculated. We can rearrange this equation to solve for fs:
fs = ma - F
Plugging in the values, we get fs = (89kg * 2.187m/s^2) - 194.43 Newtons = 0 Newtons.
This means that the force of friction is equal to the force of inertia (centripetal force), so there is no net force in the horizontal direction. Therefore, the magnitude of the total force between the bike tire and the road is equal to the centripetal force, which we calculated to be 194.43 Newtons.
Hope this helps! Keep up the good work.
  • · Replies 20 ·
  • · Replies 29 ·
  • · Replies 21 ·
