Integral in Physics: Electric Flux, Potential, Fields & Charges
  • Context: Undergrad
  • Thread starter Thread starter david90
    Integral Physics
The discussion revolves around the application of integrals in the context of electric flux, potential, fields, and charges in physics. Participants explore how integrals are used to calculate total charge from a uniformly charged distribution and the conceptual differences between mathematical and physical interpretations of integrals.
  • One participant expresses confusion about the connection between integrals in calculus and their application in physics, particularly regarding the use of dq in charge distribution problems.
  • Another participant explains that an integral can be viewed as a sum, illustrating this with an example of calculating total charge in a charged circle using both direct multiplication and integration.
  • A participant cautions that applying the fundamental theorem of calculus in physics can be tricky and emphasizes the importance of expressing dq in terms of spatial dimensions like dx.
  • There is a discussion about the need to integrate "in the right direction" and how the choice of limits affects the outcome of the integral.
  • Some participants question the transition from an integral expression to a simplified result, seeking clarification on the integration process and variable changes.
  • One participant acknowledges that the explanation helped clarify their understanding, though they still feel uncertain about some aspects.
Participants express varying levels of understanding and confusion regarding the application of integrals in physics. There is no consensus on the best approach to integrating in this context, and multiple viewpoints on the interpretation of dq and integration limits are presented.
Some participants highlight the need for clarity on the assumptions involved in integrating over spatial dimensions and the implications of treating constants in integrals. The discussion reflects a range of familiarity with calculus and its application in physics.
This discussion may be useful for students learning about the application of calculus in physics, particularly those grappling with concepts of charge distribution and integration techniques.
david90
I'm doing electric flux, potental, fields and charges right now in my physics class and I can't make the connection between integral and physics. For example, my teacher used dq with a uniformly charge distrubution problem. My calculus class uses integral to find area under a graph (I get that) and now my physics teacher is use it to find total charges which i don't understand why. Does integral have a different meaning in term of physics?
The integral is just a sum. For example, let's say you want to figure out how much charge there is in a charged circle of metal. The circle of metal is one meter in radius and has a linear charge density [rho] of, say, 1 coulumb per meter (yes, it's HUGELY charged!:wink: ).
What is the total charge? Obviously, it's just the circumference of the circle times its charge density:
Q = 2 pi R [rho]
= 2 pi (1) (1)
= 2 pi coulombs
However, you could also obtain the same result by integrating. What you're going to do conceptually is break down the circle into a lot of little tiny pieces, each with it's own little tiny charge, and then sum up the charge over all the little tiny pieces. In the limit as the pieces get very small, you're doing an integration.
So, let's investigate a small piece of the circle. If an arc length is called s, a little tiny piece of an arc length is called ds. If charge is called q, then a little tiny piece of charge is called dq. How much charge does a tiny piece of the circle have on it?
dq = [rho] * ds
It has a charge equal to the linear charge density [rho] times its length, ds.
Now we can integrate all these little tiny pieces of charge over the whole arc length of the circle (2 pi R), like this:
Integral from 0 to (2 pi R) of ([rho] ds)
which is just 2 pi R [rho], exactly as we found before.
Does this make sense? Let me know if anything is confusing.
- Warren
If you're just in first semester calculus, then it can lead you to the wrong answer to consider the integrals the same way. The fundamental theorem of calculus can be a tricky thing to apply to physics. Really, for purposes of calculation, the integral that explicitly contains "dq" is useless to you, but it has the most direct physical meaning. You need to get dq in terms of dx (and probably eventually you will be dealing with dy and dz, and sometimes in polar coordinates you will have some dr or dθ). The main thing that you want to make sure is that you're integrating "in the right direction." For instance, if you have a line charge, λ, on the x-axis, then dq becomes λdx. Sticking this into the integral leaves you with the decision to chose your limits. If you chose x = [a,b] you will get the negative of what you would get if you integrated on x = [b,a].
That's true, most integrals in physics are over some spatial dimension(s).
- Warren
Integral from 0 to (2 pi R) of (P ds)
which is just 2 pi R P, exactly as we found before.
I don't see how u go from 0 to 2pi R |p ds to 2pi R P.
Did u integra with respect to ds? Dont u have to change it to
something else?
something else?
Btw, U did turn on a light bulb inside my head. it is just a little
dim.
:smile:
something else?
Yes, I integrated with respect to ds. What's the value of this integral:
Integral from 0 to x of (ds)?
It's just x, of course. The same thing applied here. [rho] is a constant and can be pulled out of the integral.
- Warren
  • · Replies 30 ·
  • · Replies 21 ·
  • · Replies 25 ·
