Thread Closed
on operator commutation
Share Thread Thread Tools
May17-05, 12:07 AM   #1
Hi, I have a question,
As it is said in QM, if two operators commute, they have so many common eigenstates that they form a basis. And the inverse is right.
Now there is the question,
if A,B,C are operators, [A,B]=0, [A,C]=0,
then is "[B,C]=0" also right?
If we simply say A and B, A and C both have common eigenstates, so B and C have common eigenstates, so [B,C]=0, it seems to be right.
But in QFT, if x,y spacelike, then [\phi(x),\phi(y)]=0,
if the above is right, then we can find a point z which is spacelike according to two non-spacelike point x,y to make any non-spacelike [\phi(x),\phi(y)]=0. It looks like a paradox.
thank you!
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> Promising doped zirconia
>> New X-ray method shows how frog embryos could help thwart disease
>> Bringing life into focus
May17-05, 01:48 AM   #2
Recognitions:
Homework Helper Homework Help
> If A,B,C are operators, [A,B]=0, [A,C]=0,
No, it's not right. For a counterexample in the usual QM variables, let [tex]A=x, B=y, C=p_y[/tex].
For a counterexample in the Dirac gamma matrices,
let [tex]A=\gamma^0, B=\gamma^1\gamma^2, C=\gamma^1\gamma^3[/tex].
For a counterexample in QFT, replace the gamma matrices with your favorite four anticommuting field variables.
In each of these counterexamples, A commutes with B and A commutes with C, but B and C do not commute.
Carl
May17-05, 01:50 AM   #3
Quote by wangyi
No. The angular momentum operators give a counterexample: A = L^2, B = L_x, and C = L_y. Then [A,B] = [A,C] = 0. But [B,C]= [L_x, L_y] = ih L_z.
It is true, however, that [B, C] commutes with A. This can be seen from the jacobi identity
[A, [B, C]] + [B, [C, A]] + [C, [A, B]] = 0.
May17-05, 01:56 AM   #4
Recognitions:
If A has no degeneracy in its eigenvalues, then your logic works. In the presence of degeneracy, A can arrange to share a different set of eigenstates with B than it shares with C.
Carl
May17-05, 04:24 AM   #5
Recognitions:
[A,B]=0 means you can find a set of eigenstates common to A and B.
[A,C]=0 means you can find a set of eigenstates common to A and C.
That doesn't imply these two sets are the same, so it will in general not give a set of eigenstates common to B and C.
May17-05, 06:08 AM   #6
Thank you all, i see :)
Thread Closed
Thread Tools
Similar Threads for: on operator commutation
Thread Forum Replies
lim inf and product commutation Calculus 1
commutation property Linear & Abstract Algebra 9
commutation of operator Advanced Physics Homework 1
Commutation Relation General Physics 0
commutation relation Quantum Physics 10
