Medal Detector Myth: Unveiling the Truth
  • Thread starter Thread starter PrudensOptimus
    Detectors
The discussion revolves around the concept and functioning of metal detectors, addressing myths associated with them, and exploring personal experiences with metal detectors in various contexts, such as airports and medical situations.
  • Personal anecdotes
  • Some participants clarify that the devices referred to are metal detectors, which send electromagnetic waves and detect the presence of metals based on their reflective properties.
  • Others argue that certain devices, like those found in stores, may not function as traditional metal detectors but rather detect specific tags in products.
  • A participant raises a question about why surgical steel in their arm does not trigger metal detectors, suggesting it could be due to the type or amount of metal.
  • Some participants propose that metal detectors are calibrated to ignore small amounts of metal, which could explain why some individuals pass through without detection.
  • Personal anecdotes are shared regarding experiences with metal detectors, including instances where items like underwire bras and belt buckles set off alarms.
  • A humorous myth is mentioned regarding metal detectors being able to detect alien implants, indicating a playful aspect to the discussion.
Participants express a mix of agreement and disagreement regarding the functionality of metal detectors, the types of metals that may or may not trigger alarms, and the myths surrounding them. No consensus is reached on the broader implications of these devices or the myths associated with them.
Some claims about the calibration of metal detectors and the specific types of metals that may be ignored remain unresolved, as do the implications of personal experiences shared by participants.
PrudensOptimus
Hi,
I always fascinated by the idea of Medal Detector, they are everywhere. In Libraries, stores... What is the myth behind those machines?
Hopefully you mean metal detector. The deal is that they send electromagnetic waves in the direction you point them, and tell you when the signal comes back.
They work because metals reflect EM waves. Visible light is a type of EM wave, and we all know how metals are generally shiny.
Those are not metal detectors. The only place you'll find metal detectors are at airport security. They detect the signal from a tag inserted in the product.
Though if they are, I think I'll not visit the neighborhood where PrudensOptimus lives. :rolleyes:
In reality these devices are loosely tuned oscilators. When a piece of metal is inside the EM field the reactance of the tuning circuit is altered and the frequency changes. The changing frequency and not an echo is used to detect the presence of a metal.
Here is a related question:
I have about 2 ounces of surgical steel in my arm. Why can I pass through metal detectors without this being detected?
Is it the type of metal?
Is it that it is inside my arm?
It is probably the amount. I remember eharing that metal detcetors are callibrated to ignore metal in amounts too small to be a weapon. Only makes sense; can't have them going off every time someone with fillings in their teeth tries to walk through.
My mom has a screw in her leg, and she sets off the metals detectors everytime she goes to the airport. But that's a lot more than two ounces.
i went through a metal detector last year at NBC studios. it went off, and they made me go back. i started to take out my change and he said "no, that wouldn't set it off".
turns out it was the foil from my gum wrappers!
The metal underwire in my bra set off the metal detector at the airport a couple of years ago, my daughter's small belt buckle set it off last time.
It looks from this site:
Metal Detectors
Address:http://www.mwscientific.com/metal_det_test_sf.htm
like surgical pins aren't likely to set a detector off. Is your "2 ounces" the sum of the weight of several individual pins? If not, then you're just lucky.
No one has tackled the "myth" of metal detectors yet. The myth associated with metal detectors is that they can be set off if you have been abducted by space aliens and had an alien implant inserted into your body somewhere.
Nice, zooby :-p
I suppose he merely meant to ask "how do these machines work?"
Or maybe he was looking for answer like yours. :rolleyes:
He was clearly fishing for info about space aliens.
The zipper in my pants set off the alarm at the airport. You just need to tell them that you have something in your arm, and ask for them to search you with the want, and you will be set.
I have to go through metal detectors frequently for professional reasons and really wish I could buy all non-metalic clothing (wooden belt buckles, zipper free clothes with non-metal buttons, etc.).
Get button up pants :D
If you think that I'm not going to pursue this in GD, you're nuts.
If you're implying that to search Crosson is to want him, then I pity anyone in the security business. Elsewise, I will assume that you meant wand. :-p
If you were a professional nudist, this wouldn't be a problem.
Okay, I'm going back to GD where I belong...
I go through airports 8+ times per year, I've never been stopped.
Zipper in your pants... Right. You mean the foil-wrapped cuke.
Is there anyone that doesn't like that movie?
:confused:
  • · Replies 49 ·
