Speeding into a supersize black hole
  • Context: Graduate
  • Thread starter Thread starter Anders Lundberg
    Black hole Hole
The discussion centers on the behavior of a spaceship approaching the supermassive black hole in galaxy NGC4261, which has a mass approximately 100,000 times that of the Sun. Despite achieving near light-speed velocity, the spaceship cannot exceed the speed of light due to the effects of general relativity. The gravitational field of the black hole accelerates the spaceship, but the velocity measured in Schwarzschild coordinates remains zero as it approaches the event horizon. The concept of rapidity is introduced as a more relevant measure than traditional velocity in this context.
  • Understanding of general relativity and its implications on velocity and mass
  • Familiarity with black hole physics, particularly the Schwarzschild solution
  • Knowledge of relativistic concepts such as kinetic energy and rapidity
  • Basic grasp of astrophysics, specifically the dynamics of objects in strong gravitational fields
  • Study the Schwarzschild metric and its applications in black hole physics
  • Learn about the concept of rapidity in special relativity
  • Explore the implications of gravitational fields on the motion of objects approaching black holes
  • Investigate the effects of relativistic mass increase on objects in strong gravitational fields
Astronomers, physicists, and students of astrophysics interested in black hole dynamics and the effects of general relativity on high-velocity objects.
Anders Lundberg
The galaxy NGC4261 is believed to contain a black hole that weighs about one hundred thousand times as much as our sun, with a diameter the size of our solar system. (http://www.damtp.cam.ac.uk/user/gr/public/bh_obsv.html)
Now, imagine that we clear the space around the black hole and use some kind of spaceship to first build up a near light speed velocity. Then, from a distance of a few "light days" (we suppose that this black hole has a diameter of almost a "light day") we aim straight at the black hole, turn off the engines and just plainly falls towards it.
My question is; If the spaceship already is at very near light speed, why doesn't the massive gravitational field from the black hole manage to accelerate the spaceship to above light speed before it reaches the black hole? Any relativistic mass increase of the spaceship would not make any difference since it is accelerated by a gravitational field (and not by its engines), so what is stopping it?
What happens when things fall in a gravitational field? They gain kinetic energy.
There is no limit on kinetic energy. You can fall towards a black hole and gain nearly infinite amounts of kinetic energy.
But nearly infinite amounts of kinetic energy are not enough to travel faster then the speed of light. Better luck next time.
Some thought needs to be given as to how the velocity is being measured. For instance, the coordiante velocity dr/dt for an object falling into a black hole will be zero! The most convenient number is not a velocity, but a rapidity - dr/dtau, which is the rate of change of the Schwarzschild coordinate 'r' with the proper time 'tau'.
For more on rapidities in SR see for instance
http://math.ucr.edu/home/baez/physics/Relativity/SR/velocity.html
  • · Replies 51 ·
  • · Replies 67 ·
  • · Replies 20 ·
  • · Replies 21 ·
  • · Replies 17 ·
  • · Replies 17 ·
  • · Replies 18 ·
